leaf spring Hilux drag racing launch help?
If you nothing but leaf springs on the back, you could so a set of drag shocks in the front and back, along with a set of cal trac bars. Guys here are pulling deep into the 1.x 60 ft using that and slick. Hard to tell from the vid but were you running slicks on them passes?
I have 31 x 10.5 mud wranglers on it at 20psi air pressure (white rims on rear)
I tried some 28 x 10.5 street tyres and gained 4mph but wanted to break loose up to about 120km/hr so i put the mud wranglers back on.
I'm babying it off the line trying to find the fine line between traction and the smoke show as a result the times are very erratatic and I usually get knocked out the first run after we dial in. very inconsistent. I'm the only guy on our drag strip running a 4x4 car but it is probly the crowds most favourite car there.
I watched that video and didn't see any tire spin or traction loss off the line. And he was asking about trying to tweak the tune to build boost at the line. Maybe I misunderstood the problem, but I thought he was trying to improve his 60 ft from 2.4 sec.
He is launching in 4x4, correct? He ought to be.
How soft do you blokes have the rear of your trucks? say if you walk around the back and push up and down.... do they go up and down much? and what about the front of your cars? up and down much by hand? (lol sounds funny but you know what I mean.)
2wd launch, The front shaft is home made from an old quad bike axle and not very strong... just strong enough to get me out of a bog. I needed a skinny shaft to clear the th700r4 when i put it in the truck.
The launch's in the video are at idle and then babying it to 60ft or just before and feeding the pedal into it being carefull not to brake free. (well as best i can anyway)
He is having trouble now leaving under no boost, jeeze.
