TIME SLIP DATABASE
Dialing back your vehicle
Old Oct 17, 2007 | 11:58 AM
Quik's Avatar
5 year bitches!
Default Dialing back your vehicle
Thru a PM I was thinking of how you would Dial back your vehicle. What are some of you doing or have seen to dial back vehicles. Throttle stops? Tune? name your ways you have seen and etc
I know ppl do this to be consistant in certain racing classes and figured what the hell since its the end of racing time to share your tricks of the trade
Old Oct 17, 2007 | 12:01 PM
silver-mod-o's Avatar
Hunt&Fisherator
I have seen a guy "shim" his gas pedal... no joke.. it was the most ghetto thing I'd ever witnessed... he had pieces of rubber he velcro'd together to make it thicker and thinner... limiting pedal travel...
I know some people here use their tuning to take a couple degrees timing out, or lower shift points and land on a certain number... there's a bunch of ways to do it.
Old Oct 17, 2007 | 12:07 PM
Quik's Avatar
5 year bitches!
figure lets share them, heres one how would you do thta with a GayByWire. this could be a boosted application or NA appication. this would help ppl out if wanting to do this
Old Oct 17, 2007 | 12:17 PM
bluecajun5.3's Avatar
11 Second Truck Club
humm...
my DBW is very consistent.
2 different times at 2 different tracks.
ex: .84, .85, .86, .87
Old Oct 17, 2007 | 01:29 PM
krambo's Avatar
I pulled 3* across my HI octane table and it cut .3 off my 1/4 times. I thought it would be more consistant however it wasn't. Once you lock down the tune, you should be consistant at max effort. I never tried early shifts (like 4500).
Old Oct 17, 2007 | 05:26 PM
hemidup's Avatar
With the 64 Dodge running in NSSA class. We run the car heads up in a 10.00 index. If at any given track the car starts running a 9.98, we just add ballist. We use 25lb bags of lead shot. If at any given track the car runs a 10.10 or slower, we're normally screwed. I think that adding weight would also be a choice. It all depends on how much slower you want to go.
Old Oct 18, 2007 | 08:29 AM
litreddevil's Avatar
Banned
DBW the thing under the pedal will work,the pcm will not see 100% throttle angle
Old Oct 18, 2007 | 09:13 AM
zippy's Avatar
With drive by wire, you can just go in and set max throttle opening vs. pedal position. Basicly at wide open the throttle blade won't be open all the way.
Oobray
Jun 13, 2022 03:38 AM
Corvette454l88
Sep 1, 2016 01:24 AM
thunder550
Oct 8, 2015 04:53 PM
superchomper2003
Aug 26, 2015 09:39 AM
Mr. Chainsaw
Aug 14, 2015 12:54 PM
