TIME SLIP DATABASE
09 ecsb w trick stage 2 @ 8psi - 14.0 at 98
Old Aug 25, 2012 | 05:12 PM
Choda's Avatar
Default 09 ecsb w trick stage 2 @ 5psi - 14.0 at 98 VIDEO
New best. Full weight. Left in 4 wheel and at 5 lbs. Everything else but turbo kit is stock.
What do u guys think? Seems reg?
Old Aug 25, 2012 | 05:23 PM
nonnieselman's Avatar
Yikes. I went 13.2@104 on 6# on my stock lq4, stock 80e and 3.42.
For 8# id expect atleast a low 13 in the heat. What was your 60'?
Old Aug 25, 2012 | 05:49 PM
ZO6Ted's Avatar
It will get much better in time.
Old Aug 25, 2012 | 06:25 PM
lglowe's Avatar
Who tuned it. Mph seems lil low for sure
Old Aug 25, 2012 | 06:29 PM
ssswannabe's Avatar
I would think u can get into low thirteens were you able to hook up? Still a decent time but u should atleast beat my truck with that turbo.
Old Aug 25, 2012 | 08:08 PM
Choda's Avatar
2.1 60 foot
New era. Makes 400 wheel
I've been drag racing for years, it doesn't seem like its got any more in it.
Needs a convertor and sub 2 sixty foot
5100 w out me and western ny track. It didn't spin or have any problem launch, it's just a boat
Old Aug 25, 2012 | 09:03 PM
tiffo60's Avatar
We're you able to build boost on the line?
Old Aug 25, 2012 | 09:18 PM
jrmchevyman's Avatar
Try to build up boost off the line, get a higher stalling torque converter too..
Did you at least try to get the rpm's up while applying the brakes, before it hit the green light? The stock torque converter stalls at about 1700-1800 rpm so try to get the rpm's up around that next time before it turns green light on the tree. Soon as it hits green, floor it..
Old Aug 25, 2012 | 10:31 PM
stock48's Avatar
9 Second Truck Club
Just needs more boost, converter, and tuning. It's prob pulling a bunch of timing for IAT, and or getting KR. Water meth also helps a ton on the hot days.
Old Aug 27, 2012 | 10:13 AM
Choda's Avatar
yeah i brake boosted it to 5psi. anything over and the brakes dont hold it.
i bring it up to about 2K and let it eat.
This is against a fellow PT'er.
kinda hard to launch it, turn the 4wd off, keep it straight and record. =] im getting good though.
