09 ecsb w trick stage 2 @ 8psi - 14.0 at 98
Maybe a stupid question, but did your tuner remove the speed limiter? The stock limiter is 98mph. After I installed my Whipple, I ran it at the track for the first time and kept hitting 98mph traps. I looked at the tune supplied to me by Whipple and they never removed the speed limiter.
14s??? Your truck should be low 13s high 12s especially with 4hi. What motor is in your truck? I made over 400whp on just 5lbs no meth on a non load with my 5.3. Are the 4 speeds and 6 speeds that different in putting power down? Even before I went turbo I put down 308hp on my 5.3 with tune cutout only.
from Western New York
speed limiter is taken out
5.3 motor stock 4L60E trans
the mph is there for a low 13 just cant get it outta the hole. Watch the vid guys. i bring it up to 5 psi and let it go. it runs good just takes a while to get moving.
a trans with convertor would make it et a lot better.
I also take it out of 4WD at the top of first before the 1-2 shift
no way of monitering IAT. they should be fine with the front mount and the trucking being cold when racing
