Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
New Hemi Intake, ported Heads and Programmable PCM!!!
Old Jan 19, 2006 | 11:46 AM
Toe's Avatar
Toe
Default New Hemi Intake, ported Heads and Programmable PCM!!!
Got these from DTW.
I wish I could read the fine print on the Programmable Engine Managment System. I am also worried that this might be for the 04+ hemi's only as the 03's have a different controller, but then again most of the hookups may be the same so it may just be a matter of taking the 03pcm and tcm out and replacing it with this one new unit.
Old Jan 19, 2006 | 01:52 PM
I saw the post on DTW, it's spreading to other forums. I just wonder how much they'll charge? The "Mopar" CAI is really a AFE CAI and they charge quite a bit more for it.
Jim
Old Jan 19, 2006 | 02:26 PM
Fogle07's Avatar
get me some part numbers guys. i work at a dodge dealer. ill get you a good deal.
Old Jan 19, 2006 | 02:37 PM
MrDestinE's Avatar
Does that REALLY say Programmable!!! Perhaps there IS a God!! J/K but it's more than about time.... and I am also wondering about the 03 question...
TJ
Old Jan 19, 2006 | 02:50 PM
ktmrider's Avatar
Thanks for the hookup offer Fogle! We'll keep you in mind.
I really hope these pan out. This is the first I have seen on the products. Hopefully they are for all the 5.7L Hemi vehicles and not the crate motor only! I would be interested....
Old Jan 19, 2006 | 02:57 PM
MrDestinE's Avatar
On a second look it does not look like that is going to work at all on any of the trucks, it is just made for installing the Hemi in a Hot Rod swap situation..
it would not do all the things controlled by the present PCM...
TJ
Old Jan 19, 2006 | 03:11 PM
Toe's Avatar
Toe
Hmm if thats the case I wonder if this new pcm and goodies could be installed on a truck, keep the stock pcm for controlling stuff like the guages, abs, comfort features, then have this new pcm control your engine and tranny. Would be a hack but if it works I'll do it. I'll be getting a Jeep Liberty Desiel in the fall so my ram will become my toy so I can afford to screw around with the computer, and not worry about getting to work if I screw up.
Old Jan 26, 2006 | 07:41 PM
Blown330's Avatar
Looks to say "....Calibration Included" first work looks like "Base" but that is just a best guess and "OEM Engineered Wiring Harness" for the second line.
Old Feb 2, 2006 | 12:47 PM
rumblebee1638's Avatar
Do you guys really want to go back to a carb? That is not a fuel injection intake.
Old Feb 16, 2006 | 03:06 PM
kkd60's Avatar
actually, yes that is a fuel injected intake. It is very similar to the m1 manifold for 318's and 360's.
