TH-400 to TH-700 r4 swap '77 rcsb
Old Jul 26, 2010 | 04:32 AM
fspeedster's Avatar
Default TH-400 to TH-700 r4 swap '77 rcsb
Like the title say's...what's needed? Any write up's? tips? Help!
Old Sep 20, 2010 | 08:55 PM
hotrodhorton's Avatar
make sure you get the tv cable set right or it will not shift and can burn the trans up. i found that out the hard way. you might have to get your drive shaft cut down i would measure the trans lengths. new trans mount and thats all i can think of at the moment
Old Sep 20, 2010 | 09:51 PM
Big Port Jimmy 6's Avatar
Find a "B"body car tail housing. They move the trans mount back to the 400 mounting position. B body are Impala, Caprice, Roadmaster RWD Fleetwoods etc. You will need a new front slip yoke 700s use the same yoke a a 350 the 400 yoke is too large.
Old Sep 22, 2010 | 04:35 PM
you can change out the cross member if you cant find a tail shaft
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
OHsixLS3
Dec 27, 2016 09:30 AM
greedygenius
Sep 3, 2015 06:51 AM
creekrat
Aug 2, 2015 01:27 AM
