TH-400 to TH-700 r4 swap '77 rcsb
make sure you get the tv cable set right or it will not shift and can burn the trans up. i found that out the hard way. you might have to get your drive shaft cut down i would measure the trans lengths. new trans mount and thats all i can think of at the moment
Find a "B"body car tail housing. They move the trans mount back to the 400 mounting position. B body are Impala, Caprice, Roadmaster RWD Fleetwoods etc. You will need a new front slip yoke 700s use the same yoke a a 350 the 400 yoke is too large.
