rear end issue...
Old Aug 5, 2009 | 11:40 PM
1LowC-body's Avatar
Default rear end issue...
so heres the deal i have a 1991 c1500 pickup. just got done building my 383 not even fully broke in yet and now im having rear end problems. i know, i know, the rear end is the same one that was behind the v6 so everyone is gonna tell me its shot, to weak, blah blah, but i just want everyones opinion before i start tearing it down and replacing everything. heres the deal, it started popping a little when taking off easy (have a manual trans) wasn't a bad pop just a small one but noticable (has a new UV joint). today i got it out and was riding around with some friends and it popped a couple of times and now when driving it makes a loud winding sound (simular to a car driving fast in reverse). Now my thought it the gears aren't meshing right and something has gave out to make this happen. I plan on tearing it down tomorrow afternoon and see what i find. But any chance this could me a bearing or an axle or hopefully not the pinion? Or is it just simply the gears in the rear end are worn out? Its a 10 bolt open diff (i want a possi anyways so this would be a good time to get one). So, what is everyones opinion on the issue? Thanks guys
Old Aug 6, 2009 | 12:34 AM
Atomic's Avatar
I have a gauge for that
I bet its the spider gears.
Old Aug 6, 2009 | 01:05 AM
1LowC-body's Avatar
i hope its something simple like that ill find out when i pull it tomorrow ill let you know what i find.
Old Aug 6, 2009 | 01:28 PM
MossyOakSilverado's Avatar
You can make any rearend last, it just depends on how you drive it. You could beef up a 10 bolt to handle cruise-in drives and the occasional throttle jab or shot down the track. Just stay away from any type of slick, hard hooks, or high rpm launches. Being that you have a manual trans, you are loading and unloading the ring n pinion with each **** most times. With an automatic there is constant pressure. Id throw a nice ring n pinion in, some nice axles and c-clip eliminators and go with it.
Because the 12 bolts out there under our trucks are a dime a dozen, itd be worth putting a good one under. Alot of trucks that are being parted out now could give you instant relief of this issue and get you some time before a good rebuild is in order. I am looking into a 12 bolt for my 83 C10. Im not gonna run the **** out of it with slicks. Itll be a cruiser and semi dd.
Old Aug 6, 2009 | 08:13 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You could re-build the 10 bolt but you won't know how bad it is till you get in there...
Best option would be a 14 bolt 9.5 SF rear end from a heavy 1/2 ton, light duty 3/4 ton 88-98 pick up. if its 2wd it will be the 64.5 wms-wms and if its 4x4 it will be the 67.5 wms-wms.
Haven't seen a 12 bolt for the 88-99 style pick ups and I wouldn't waste the time trying to make a 12 bolt fit.
Old Aug 6, 2009 | 11:05 PM
1LowC-body's Avatar
i will definately look into the 14 bolt. would it be a direct bolt on? if so it will deffinately save me a lot of time and prolly money too. are these posi tracs or open?
Old Aug 6, 2009 | 11:22 PM
1LowC-body's Avatar
does anyone know if my 91 model has 30 spline or 28 spline axles?
Old Aug 7, 2009 | 08:46 AM
1FastBrick's Avatar
should bolt right in. you will end up needeing a conversion U joint and you may have to shorten your drive shaft 1/2 deppending on your set up.
Old Aug 7, 2009 | 11:16 AM
team39763's Avatar
I think I remember reading that in 88 they started switching the truck 10bolts to 30spline. So your 91 should be 30spline.
Old Aug 7, 2009 | 11:30 AM
garcia's Avatar
get yours built or get a built 12 bolt just for the peace of mind
