9/10 drop
hi im new to the site but im curious has any one ever seen a 9/10 drop (in the front being 4in lower control arms, 2in spindles, and 3 in springs) and the rear being 2in shackle 2in hanger and a 6in flip kit ? and if so how much modification is needed ? like can i keep my inner fenders in the front or do i have to mod something up? and in the rear instead of going with a regular c notch would i have to go with a monster c notch? and comments or answers would be much apperciated
are you saying put a bigger rim on ? would the bigger rim rub worse ? i plan on putting a pretty small sidewall on the rallyes when it gets dropped to have clearence
I just don't see that big of a drop working on an obs with 15s and small tires. It would literally be sitting on the frame. It may work with a huge wheel but would take extensive work to the fender wells for clearance. I had a 93 RCSB back in HS that had a 4/6 drop on 15s with 275/45 tire and it had very little ground clearance. The front crossmember was only about 3 inches off the ground.
wouldnt reccomend the lca and spindle combo but here is what youl need to do monster notch out back flip kit shackles and overload leaf removal. up front I would do spindles with a 3 inch spring then take one more coil off the spring. Your gonna have to notch for tie rods or get notchless... that will be more like a 7/9 my buddy has his truck 6/8 for 2 weeks before he raised it back up
