9/10 drop
Old Sep 13, 2012 | 08:30 AM
John Baker's Avatar
Registered User
Talking 9/10 drop
hi im new to the site but im curious has any one ever seen a 9/10 drop (in the front being 4in lower control arms, 2in spindles, and 3 in springs) and the rear being 2in shackle 2in hanger and a 6in flip kit ? and if so how much modification is needed ? like can i keep my inner fenders in the front or do i have to mod something up? and in the rear instead of going with a regular c notch would i have to go with a monster c notch? and comments or answers would be much apperciated
Old Sep 13, 2012 | 08:36 AM
John Baker's Avatar
Registered User
btw its a 96 chevy 1500 ext cab its has 2in shackles on it now and 8in rallyes
Old Sep 13, 2012 | 08:44 AM
boosted_blue's Avatar
I don't think it's possible, especially on 15s. Lowest static drop I've seen on an obs on 15s is 5/7.
Old Sep 13, 2012 | 08:49 AM
John Baker's Avatar
Registered User
are you saying put a bigger rim on ? would the bigger rim rub worse ? i plan on putting a pretty small sidewall on the rallyes when it gets dropped to have clearence
Old Sep 13, 2012 | 08:51 AM
John Baker's Avatar
Registered User
I could change the rim and tire combo if it was need though
Old Sep 13, 2012 | 09:00 AM
I just don't see that big of a drop working on an obs with 15s and small tires. It would literally be sitting on the frame. It may work with a huge wheel but would take extensive work to the fender wells for clearance. I had a 93 RCSB back in HS that had a 4/6 drop on 15s with 275/45 tire and it had very little ground clearance. The front crossmember was only about 3 inches off the ground.
Old Sep 13, 2012 | 09:08 AM
*275/60 tire
Old Sep 14, 2012 | 08:24 AM
Devs93's Avatar
wouldnt reccomend the lca and spindle combo but here is what youl need to do monster notch out back flip kit shackles and overload leaf removal. up front I would do spindles with a 3 inch spring then take one more coil off the spring. Your gonna have to notch for tie rods or get notchless... that will be more like a 7/9 my buddy has his truck 6/8 for 2 weeks before he raised it back up
Old Sep 14, 2012 | 08:25 AM
Devs93's Avatar
im 5/7 with 295/50/15 and 245/50/15s
Old Jan 2, 2013 | 07:42 PM
mooseknuckles's Avatar
any more than 5" of drop on the front and the lower cntrol arms will hit everything in the road unless you do a "Z"....your front tires will also want to rub the inner fenders......if your stuck on doing a low static drop, I'd do a 3 inch "Z", 3" drop spindles, and maybe cut one coil of the front springs....that would give 6-7" of drop...and keep the control arms off the ground. do a flip in the rear with some drop hangers or shackles, a small c-notch, and remove the bump stops, that will give you about 7-10" of drop... A 7-9" drop is prob the most you'd want on the street, doin the "Z" is key to keeping some ground clearance...if you have side tanks, they will also want to rub in the driveways and such....
USMCvet0311
Jan 16, 2016 06:04 PM
Gadgetized
Oct 22, 2015 09:06 AM
smok'nZ
Oct 6, 2015 01:14 PM
twake_410
Sep 25, 2015 10:09 PM
