1990 k2500 4wd not working
Old Mar 3, 2014 | 08:31 AM
Chevy_King1500's Avatar
Exclamation 1990 k2500 4wd not working
As the title says I have no power to the actuator.
Things I have checked.
-Actuator works when you hook it up to 12v
-4x4 fuse is good
-4x4 lights are intermittent
-not getting power to the actuator plug
Old Mar 3, 2014 | 10:00 AM
BigBlock90's Avatar
-4x4 fuse is good
ive had this problem on several of mine aswell. its 99% of the time the screw in activator switch on the side of the transfer case. when you pull the lever insidethe cab, it enguages the transfer case and then that switch enguages the front actuator. replace that switch and you should be good to go! its on the driver side of transfer case towards the upper side. its called a (transfer case switch)
Jamie
Old Mar 3, 2014 | 03:39 PM
Old Mar 3, 2014 | 04:30 PM
BigBlock90's Avatar
how much was your new one? been a while since ive bought any and dont remember. they were always fairly cheap for what i recall.
Old Mar 3, 2014 | 04:36 PM
didnt get the new one yet. so thats the right part?
Old Mar 3, 2014 | 04:37 PM
BigBlock90's Avatar
yessir thats it
Old Mar 4, 2014 | 07:46 PM
heres the right part
located on the driver side next to the floor shift rod..
you need a deep 23mm socket, its easiest if you go from the rear of the transfer case and reach over it.
working great now.
at first i couldnt see the switch because of all the dirt
Old Mar 4, 2014 | 09:28 PM
BigBlock90's Avatar
working great now.
glad you got it fixed!! ive had to replace several of those on my old body style trucks that i used for hunting and beating around in so i was sure that was your problem!!
Jamie
kyle's v
Oct 4, 2015 12:37 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
Allgonoshow
Jul 29, 2015 04:21 PM
Kaldar
Jul 27, 2015 06:42 PM
MileHighSierra
Jul 22, 2015 11:19 PM
