Need help if i can put Camaro rims on my Chevy
Is the 92 Chevy your speaking of a 5 lug pattern ? 2 wheel or 4x4 ? More info would be helpful.
Anyway you will most likely have to use wheel adaptors.
The truck will be 5on5 bolt pattern , and I know the corvettes and older camaros are 5x4 3/4 " bolt pattern .
Also if your planning on running wide rear tires a spacer in conjunction with the wheel adaptor will be needed for the tire to clear the inner fender of the bed.
My dad bought a 95 2 wheel drive Chevy truck that had C5 vette wheels on it .
Looks awesome but after we started investigating how they mounted the wheels with adaptors we immediately took them off , wasn't safe in our opinion , to do it right the axles would need re-drilled for the correct bolt pattern.
AHelm3
Apr 8, 2016 07:51 AM
gcsd3742
Jul 6, 2015 05:22 PM
