1978 C-10 SWB LS engine swap!
Old Dec 30, 2008 | 11:41 PM
  #191
82streetshow's Avatar
im droppin a 6.0 into my 82 model soon, any pointers on what to do and what not to do?
Old Dec 31, 2008 | 09:39 AM
  #192
bowtieguy79's Avatar
Originally Posted by chevyguy7802
Im debating right now either going with a fast 92/92 set-up or going with nitrous.....Im waiting on a nice day to get some video the weather has been pretty chitty here latley
Hows your truck been running bro?
This past week I have been working on lowering it. 30 years 200K miles make ball joints not want to give up! I have had a heck of a time getting that done. Finally got the drivers side to give up, after using a pair of pickle forks. The rear end, I pulled out 3 springs and seemed to have gotten 2" drop out of it, I ordered a pair of 2" drop shackles from Summit to add. Other than that, mine's just been sitting, to much salt on the roads right now.
Old Dec 31, 2008 | 11:56 AM
  #193
chevyguy7802's Avatar
Spend the money on the fuel system and run braided lines if you can, what are you doing for a wiring harness? I went with a nelson and it was plug and play....had very few wires to wire into the truck!
Old Dec 31, 2008 | 11:57 AM
  #194
Good deal! Yea they can be a bitch sometimes lol I need to do mine lol
Old Jan 1, 2009 | 06:35 PM
  #195
i planned on going nelson on the harness and wheatley on the tune, just to keep things simple. Did you look into possibly running 2 87 model tanks with pumps and using the stock fuel lines and just adapting them at the engine instead of running all aftermarket fuel lines? That way you keep the same 2 tank setup?
Old Jan 1, 2009 | 06:43 PM
  #196
Good deal, the nelson harness is top quality. I know there is a write up of it somewhere that street&performance did on a 73-87 ls1 swap with dual tanks, I may probably do it down the road sometime! If you ever have any questions dont hesitate to ask! If I find the link I'll pm it to you....
Old Jan 1, 2009 | 09:38 PM
  #197
did you stick with the factory gauges, im thinking i wanna go autometer somewhere down the road but wanna stick to stock for now budget wise. I know the ect and oil pressure are both 3 wire sensors so you can use those plus the volt meter gauge you can wire to work, but your SOL on speed
Old Jan 1, 2009 | 09:55 PM
  #198
I was able to use the factory lines with my 79. I used Russel tube nut to -6, It worked well.
Old Jan 1, 2009 | 09:57 PM
  #199
i found a 90 suburban cluster, has a elec speedo, all others you should be able to adapt. Some where on the web I saw a guy use a 94-9? Dodge ram cluster, looked kinda trick.
Old Jan 1, 2009 | 10:02 PM
  #200
used factory 87 model lines? do you have a pic of how it adapted?
