Miss at low RPMs in 5th gear
Old Sep 4, 2011 | 12:56 PM
Ender06's Avatar
Default Miss at low RPMs in 5th gear
My 8.1 is missing in real low rpms in 5th gear. Only when I lug it around. Usually between 44 an 50 MPH right when it is almost ready to downshift to 4th. The truck jerks a lot and hesitates. But u can still slowly pick up speed. If I throttle it a little more it will downshift and has NO miss AT ALL. I don't understand. I've changed plugs and wires and it still happens.
Old Sep 4, 2011 | 05:17 PM
Chevy_King1500's Avatar
codes? tried cleaning MAF or throttle body?
Old Sep 4, 2011 | 06:14 PM
Ender06's Avatar
No codes and I've cleans both numerous times
Old Sep 4, 2011 | 06:40 PM
smokeshow's Avatar
Mod with training wheels
How low of RPMs?
Old Sep 4, 2011 | 06:57 PM
Ender06's Avatar
I'm thinkink 1500 or just a hair more
Old Sep 4, 2011 | 08:54 PM
elaborate on the symptoms more? does the TC lock up on the 5 speed?
does it not miss in any other gear or idle?
Old Sep 5, 2011 | 09:55 AM
Ender06's Avatar
No miss at idle. I've only noticed the miss in 5th and the TC is locked. No cel.
Old Sep 22, 2011 | 09:40 PM
Ender06's Avatar
OK I have a new theory...not a good one tho. I've noticed my oil pressure all freaky. As soon as you start the motor no oil pressuse...for probably 2-3 seconds. And when it does hit normal pressure you can watch it dance. It will drop and raise about 10 psi every few seconds. Bout 8-10 seconds to be more precise. And after a cold start it has a whine in the motor for about 5 seconds when I pull out. I'm thinking bearing going bad. And its causeing one of the sensors to read funny. CAM or CRANK sensor. What do you guys think?
Old Sep 26, 2011 | 09:11 PM
xx_ED_xx's Avatar
Possible, verify that the gauge is the issue, mechanical tap right above oil filter. These things are bad about crank sensors.
Old Sep 26, 2011 | 09:24 PM
Ender06's Avatar
Ed...what do u think of the whining noise?? It worries me bad!
