i think flexplate or TC broke- help please
Old Jan 2, 2012 | 01:14 PM
lawdog49's Avatar
Default i think flexplate or TC broke- help please
i had posted in drivetrain when i first started getting some 'clunks' from the 4l80, but didn't get much response. now, last night i put it in park and hear something rattling around underneath the truck. sounds like something metal bouncing around inside the bellhousing. trans temps still fine and shifting is fine except that clunk periodically that is more frequent, and also some slipping when starting off from a light. also some strange whining when decelerating. gotta get to a buddy's shop and check it out, but is it possible the 8.1 has managed to break a flexplate or torque converter? just a blackbear tune and catback, otherwise factory setup (4.10's and 285's if it matters).
if it is one of those two, what are best options for replacement (i do tow with this truck)- not ever gonna build the engine up just want more durable than factory parts to replace with. the 8.1 is rather torquey, especially with some of the TM removed by Justin.
Old Jan 2, 2012 | 03:08 PM
mhotrodscooter's Avatar
if its the flex plate id go with a sfi circleD, id almost bet its the flexplate, ive seen a couple stock ones crack up..
Old Jan 4, 2012 | 09:34 AM
xx_ED_xx's Avatar
I too have seen stock ones cracked. easy enough to check unbolt convertor take a mirror and light and look around the bolt holes to crank.
Old Jan 4, 2012 | 10:47 AM
lawdog49's Avatar
are these flexplates for the 8.1 trucks the same as for other LS motors that i see sold from circle d?
Old Jan 4, 2012 | 07:12 PM
xx_ED_xx's Avatar
noooooo
Old Jan 4, 2012 | 07:13 PM
xx_ED_xx's Avatar
but it is the same as a 2 piece seal neutral balance bbc or sbc 168 tooth
Old Jan 5, 2012 | 09:34 AM
lawdog49's Avatar
ok i had read that somewhere else too, looking for some confirmation. i think i read TCI makes a 168 tooth one for old style 396/427 BBC that is neutral and works. taking it to the shop today so we can take a peek and see what is broken.
Old Jan 8, 2012 | 08:36 AM
Manic Mechanic's Avatar
Check the starter for a loose bendix, that's what mine was. Also there are no aftermarket flex-plates for the 8.1/Allison combination, I realize you have a 4L80E but wanted to warn others reading this. I thought my flex-plate was broken and on Diesel place we talked about it and I ordered a plate only to find it didn't fit and the bolt pattern once measured when I had it all apart was non-standard on the converter. It may be LS but it wasn't BBC.
Vernon
Old Jan 9, 2012 | 03:00 PM
lawdog49's Avatar
Well, no luck- it's the trans for sure. broken hard parts in the case flopping around, and getting louder the more it runs. didn't want to risk something cracking the case ($1000 core on these, boys) so we shut it down. ordered a goodwrench 3 year/100K replacement. for the price i got on it (which wasn't cheap at all) you can't beat the warranty, yet still cheaper than all the performance companies builds- which have little to no warranty. i really don't need all the performance upgrades anyway for my purposes.
03chevytruck
Nov 7, 2016 04:43 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
g6t6o
Sep 26, 2015 10:57 AM
69z-28
Sep 21, 2015 07:31 AM
ALL ULL C
Aug 16, 2015 08:56 PM
