2003 Silverado 2500HD 4x4 - Which trans and transfer case?
Old Feb 27, 2010 | 06:54 PM
SpecV44's Avatar
Default 2003 Silverado 2500HD 4x4 - Which trans and transfer case?
I picked up a 2003 Silverado 2500hd 4x4 w/ the 6.0. I towed my 94 ext cab up here to Alabama today, and it seems my trans is on the way out, quickly. Before I order a rebuild kit, I want to ensure I get the exact one that I need. I figure while I have the stuff down, I will also do the transfer case. Which should I have? I would imagine the truck has a 4L80E, but unsure about the transfer case (never had a 4x4 before).
Old Feb 28, 2010 | 05:56 PM
Dgrown's Avatar
tcase depends on if it is eletric shift or manual
Old Feb 28, 2010 | 09:05 PM
SpecV44's Avatar
I figured it would, and I meant to put it in there, but when I made that post I had been up for 36 hours and forgot. It is a manual shift.
Old Mar 4, 2010 | 01:14 PM
SpecV44's Avatar
just checked the vin, and it shows it as being a NP2:
TRANSFER CASE,MANUAL SHIFT CONTROL,TWO SPEED MAN SHFT TRFER CASE(NP2)
1GCHK29U23E180779 is the vin
Would NP2 be the correct model?
Old Mar 4, 2010 | 05:57 PM
Bo185's Avatar
NP2 is the RPO code. You have the NP261 transfercase. But cawl underneath there will be a tag on the back and tell you what it is.
Old Mar 4, 2010 | 09:00 PM
SpecV44's Avatar
yeah, that is what I was told. I looked all around the case with a flashlight but found no tag. I will check again tomorrow. Thanks for the picture
Old Mar 5, 2010 | 08:59 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
If you do rebuild the t-case, be sure to put in a Transfer Case Saver (pump-rub plate).
http://www.drivetrain.com/images/sto...pump_p1_lg.jpg
http://www.drivetrain.com/parts_cata...nsferCaseSaver
Old Mar 5, 2010 | 09:02 PM
SpecV44's Avatar
yeah, i saw that on Truck-U.
On the plus side, the transfer case was EMPTY, I put fluid in it and it is silent now. I went up to 20mph in 4L and 4H, everything seems good. Now I need to find out where the fluid went to.
Old Mar 11, 2010 | 01:28 PM
hobbesnmina2001's Avatar
The transfer case fluid is not a synthetic and when people dont check it evaporates over time, I saw this on a used S10 we had picked up. You might want to flush it because with it going dry metal wear particles are sure to be in there.
5.3Okasai
Mar 9, 2022 01:07 PM
MileHighSierra
Jul 22, 2015 11:19 PM
85SS/85GN
Jul 22, 2015 12:48 PM
04BlackGmc
Jul 16, 2015 04:10 PM
Gadgetized
Jul 7, 2015 04:40 PM
