TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
funny noises and synchros
Old 11-26-2006, 02:26 PM
01-Z71's Avatar
Default funny noises and synchros
OK guys I have two questions for ya! 1 where can I get a set of vette synchros for my 4L60? #2 I just got my truck lifted and I and getting some rather loud knocks from the front end when I go into reverse with the wheel turned and some time in drive with the wheel turned. It was alligned the day after the lift went on, and i have gone through the whole front end and double checked every nut and bolt and not a one is loose. Any ideas on either would be greatly appreciated!
[IMG][/IMG]
Old 11-26-2006, 02:54 PM
4.8 Liter Of Cola's Avatar
you can get the servo from here: nonsponsor link
As for the popping noises, they could be coming from either your ball joints or your alignment being maxed out.
Old 11-26-2006, 03:45 PM
01-Z71's Avatar
I replaced all of my ball joints with the lift. What do you mean the alignment being maxed out?
Old 11-26-2006, 06:35 PM
if, in doing the alignment, the techs moved everything to the very limits to get them into alignment, that could cause some noise. Mine did.
Old 11-26-2006, 08:11 PM
01-Z71's Avatar
Well I know what I will be doing tomorrow during my lunch break.... inspecting every inch of the front end. Did you get yours fixed and if so how?
Old 11-26-2006, 09:10 PM
I'm in the process of getting it fixed. To make a long story short, after an accident I had to get the little frame brackets pulled to give me more room.
Old 11-27-2006, 12:32 AM
01-Z71's Avatar
Sorry to hear about the accident!! Wasnt caused by the clunking was it?
Old 11-27-2006, 07:54 AM
no no, not at all. some dumbass hit me in a parking lot.
Old 11-27-2006, 07:45 PM
Need More N2O Mod
mwalls54's Avatar
sounds like your cv axles. when your tbars are maxed out "which sounds like they are because of the alignment maxed" your cv axles are put in a bind and will pop and make noise. lowering the front end would help fix this. With those angles your cv axles wont last very long.
as for the servos check with FLT. they cary a full line of tranny parts and are top notch
Old 11-29-2006, 07:21 AM
01-Z71's Avatar
well my torsion bars arent' maxed, they are only about half way up. Alignment on the front is still a ways off from being maxed. However it is looking like the c/v is going to hell though. If it is no biggie, it will take no more than an hour and $90 to fix it!
lukn4trbl355
10-21-2015 11:19 PM
Infernohoe
48
10-02-2015 10:25 PM
Velocity1
10-02-2015 08:01 AM
jscherbs
09-30-2015 07:54 AM
tim wellington
09-29-2015 10:17 PM
Quick Reply: funny noises and synchros
