I agree, although if it was that close it was a big cam. A degree wheel is the way to go although with a non adjustable timing set you aren't accomplishing much other then finding out it's not right.
yep. big cam on 106icl in a flat top LS2 with larger than stock valves in milled heads. I had to cut the pistons .090 to clear the exhaust valve. luckily I didn't start cutting pistons before verifying the cam specs.
