Western CA, AZ, NV, UT, CO, NM, WA, OR, ID, MT, WY, HI, AK
Need someone to pull broken crank bolt
Old Mar 26, 2011 | 11:53 PM
08cheyennesc's Avatar
Default Need someone to pull broken crank bolt
Like the title says, I broke crank bolt inside the crank, anyone around LA have the tools and willing to do it ? , need it done ASAP
Old Mar 27, 2011 | 12:51 AM
JFOLM's Avatar
How did you break it?
Old Mar 27, 2011 | 01:11 AM
I'm pretty sure it bottom out
Old Mar 27, 2011 | 01:34 AM
black04's Avatar
My friend did that. He ended up having to pull the motor to swap in a different crank.
Old Mar 27, 2011 | 02:00 AM
I just spend two weeks installing cam LTs and DOD delete and now this happens , I wonder if the nose of the crankshaft can be tapped , it's about 4" long and use a thicker bolt instead of pulling the motor out?
Old Mar 27, 2011 | 10:00 AM
1slowz71's Avatar
**** cesar how did this happen ? man i think youl have better luk finding an ly6 then findidng some1 to pull that brocken piece on bolt out!
Old Mar 27, 2011 | 10:34 AM
knuckles's Avatar
how far in did it brake off?
Old Mar 27, 2011 | 10:35 AM
I guess I'm to heavy Erick, that thing just snap, I will try everything I can to get it out or make new thread for a bigger bolt, if nothing works and I have to take the engine out to put a new crack then I will just replace the 5.3 with a forged 6.0 even if it takes me 6 months.
Old Mar 27, 2011 | 04:49 PM
rhinosarge's Avatar
well since you know el gordo guapo erick.. i can sell you a 6.0 crank for cheap.. i have one from a lq4 laying here in my house ... still in the block
Old Mar 27, 2011 | 06:09 PM
Camaro Zach's Avatar
the only advice I will offer up is DO NOT USE AN EASY OUT! don't even try it lol
