Widebands issues
Old Jun 6, 2018 | 10:14 PM
Patrick05's Avatar
5 Year Member
Default Widebands issues
i recently installed a pillar gauges and two of them are widebands, one for each bank. They work correctly and read about 13.5-14 af/r while cruising but randomly they pick up a interference from something else or something and start reading really low or high. Iv tried moving the ground, adding another ground from battery to frame, and unplugging one of the sensors all to try to trouble shoot. Anyone ever have this problem and can shed some light on my issue?? It usually happens after a hard pull but has happened while cruising too.
Old Jun 8, 2018 | 06:41 AM
trxmxzx's Avatar
13 Second Truck Club
what brand? I have similar issues right now too, I have a Lc-2 and they suggest a power feed direct from battery- with fuse and relay setup
Old Jun 8, 2018 | 09:47 AM
Atomic's Avatar
I have a gauge for that
Are you sure its the wideband and not the computer commanding a different AFR? That is common if you still have the stuff for cats enabled.
Old Jun 9, 2018 | 07:39 AM
Patrick05's Avatar
5 Year Member
No it’s defiantly not the true af/r, it’s way off. Sometimes it’ll shoot up to like 22 or go down to 10. And I’m not sure my truck has any program for the cats? My truck still has cats tho.
Old Jun 9, 2018 | 07:47 AM
madmann26's Avatar
Well,
It's not going to stay exactly at stoich, no matter what you do.
Differences in air, temperature, barometric pressure all effect the readings.
And then there is what's called "transitional fueling", which again, alters the readings.
What do your STFT show? That's the true reading.
agreif
Jan 17, 2007 07:02 PM
hemi roid
Nov 29, 2006 10:54 AM
jephs422
May 25, 2006 10:35 PM
Procharged LM7
May 10, 2003 05:32 PM
