where are you guys running your widebands through?
Old May 4, 2006 | 08:43 PM
jephs422's Avatar
Default where are you guys running your widebands through?
I just got my LM-1 and I'm gonna mount the box somehwere out of the way, maybe by my leg on the side of the console, but I need to figure out where to run the sensor through the floor. what have you guys done?
Old May 4, 2006 | 09:18 PM
quicksilverado's Avatar
There is a rubber groment in the drivers side floor near the front of the seat. The cable for the tranny shifter goes thru it. I cut a slit from the center out and ran my cable thru there.
Old May 25, 2006 | 06:47 PM
dc96819's Avatar
Quicksilverado
Did you need an extension on the 02 for it to get in the cab.How many feet using the 02 on the drivers side.
Old May 25, 2006 | 06:50 PM
jephs422's Avatar
I ran mine through that spot, and was able to tuck the LC1 behind the drivers kick panel with no extension. However, after it was all said an done, I ended up just mounting it ALL under the cab and only ran the 4 wires I needed through the floor. All the grounds and what not needed to be under the car anyhow.
Old May 25, 2006 | 10:35 PM
Originally Posted by dc96819
Quicksilverado
No extension. I had about 3-4 feet of extra wire. It is coiled up behind the fuse panel cover. I am using an AEM wideband instead of a LC-1.
fillpot
Jul 26, 2015 07:21 PM
dantheman1540
Jul 24, 2015 01:50 AM
lxcoupe
Jul 21, 2015 02:12 AM
dantheman1540
Jul 18, 2015 01:13 PM
kdw8888
Jul 9, 2015 10:52 PM
