wideband
Old Jan 18, 2009 | 12:35 AM
way2much_01's Avatar
Default wideband
I finally got around to installing my plx dm-100 today Is it supposed to jump around everywhere? at Idle I was reading around 14.7- 15, a wot It got down to 12.5 is that where I should be? with all the stuff in my sig where should my afr be around? thanks any help is appreciated...
Old Jan 18, 2009 | 12:45 AM
DixieDevil's Avatar
When tuning mine, we always tried to keep it in the mid 13's...
Old Jan 18, 2009 | 12:56 AM
viciousknid's Avatar
Where's the Beef?
It'll bounce around. I was wondering that too on mine. It'll bounce more with a cam. just try to tune it where it's within a certain range. after a while of tuning it didn't bounce as much.
Old Jan 18, 2009 | 06:57 AM
black4.8's Avatar
that's right on where it should be
Old Jan 18, 2009 | 09:33 AM
dirt track racer 81's Avatar
12.5-12.8 at wot is were most like to run
Old Jan 18, 2009 | 09:58 AM
BlackGMC's Avatar
Resident Retard
If your tune is commanding 12.5 at WOT then yes that is where it should be, but if your tune is commanding 11.5 and your actual is at 12.5 then there is a problem with your tune... You can tell the correctness/health of your tune by measuring the difference between actual and commanded....
Old Jan 18, 2009 | 11:07 AM
Mort's Avatar
12.5 at WOT may be a little lean once you put the Procharger on. May want to get Allen to re-tune it for that. Should probably shoot for the 11.5 range depending on the max boost pressure you are planning for. Other than that it sounds about right.
If you can log (do you have EFI Live?) your Commanded and WBO2 AFR to compare the two, then that would be a good idea as suggested by BlackGMC.
Old Jan 18, 2009 | 11:10 AM
ok just didn't wanna find out [I] was runnin rich...
SS94S10
Jan 3, 2019 01:57 PM
97_ek
Sep 23, 2015 09:16 PM
madmann26
Sep 6, 2015 04:19 PM
zblee
Aug 3, 2015 03:45 AM
slowlsx
Jul 13, 2015 04:18 AM
