Who runs EfiLive COS3, semi-closed loop with MAF enabled?
Old Oct 20, 2008 | 09:30 AM
BlackGMC's Avatar
Resident Retard
Default Who runs EfiLive COS3, semi-closed loop with MAF enabled?
Since they don't have the .cax files for my operating system yet to enable Lean Cruise, I was wondering who is running COS3 with STFTs and the MAF? To enable the STFT do I just need to set the commanded AFR to what ever stoich is for my truck (my case 14.68) in the commanded AFR vs RPM table? Also if i want to command 15.5ish in the cruise cells do I just set that AFR to 15.5 instead of stioch?
thanks
Old Oct 20, 2008 | 12:34 PM
charcold-bowtie's Avatar
That sounds right. I think. Make sure to step into lean cruise, dont go from 14.68 then the next cell is 15.5. Go look at my fuel tables set by justin. i will send u my tune....
Old Oct 20, 2008 | 12:35 PM
BlackGMC's Avatar
Resident Retard
Cool, so like 14.68 - > 15.00 -> 15.5 something like that on both sides...
<------ Like todays avartar
Old Oct 20, 2008 | 12:42 PM
Yeah something like that, at least thats what he did. i dont believe the MAF should interupt anything either. Can u read tunes at you work, and which email if you can... PM?
Old Oct 20, 2008 | 12:44 PM
BlackGMC's Avatar
Resident Retard
I think I have one of your tunes up here on my work computer .... I am just kinda tossing around the idea of switching over, hopefully the new .cax files will be available for our OSs.... I am kinda hestitate to mess with anything cause I finally got the tune dialed in......
Old Oct 20, 2008 | 12:48 PM
changing your commanded shouldnt really do much. Ur still COS3, or did u go back to stock OS, **** i think u did didnt u....
Seems is u moved back to cos3, should be fine. Still would have the same VE values and maf curve...
Old Oct 20, 2008 | 12:50 PM
BlackGMC's Avatar
Resident Retard
yep I went back to the standard OS to figure out all the damn problems I was having.... I am really thinking about going back to COS now that all the damn problems are fixed!!! I really like that MAP vs RPM table.....
Old Oct 20, 2008 | 01:03 PM
yeah b3647 is awesome. And for u its the only fueling table u will need.
stealthperf
34
Feb 14, 2016 11:35 AM
V-seriesTech
Jul 28, 2015 12:28 PM
Closer_2001
Jul 21, 2015 03:25 PM
