where is the fuel pump relay trigger wire?
Old Mar 9, 2012 | 12:06 PM
brandon_6667's Avatar
cool, thanks for the info. I will probably just keep an extra relay in the glove box just in case, and will keep in mind to check the factory relay first if I ever have a problem.
Old Mar 9, 2012 | 12:14 PM
skeet's Avatar
hewy atomic, that a 12v consistant as long as the key is on? or all the time even with key off?
Old Mar 9, 2012 | 12:15 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You don't need to carry an extra relay. If you ever suspect a bad fuel pump relay, just swap the a/c relay or horn relay into it's place. They are the same part, and in the same electrical center. Makes it really easy!
Old Mar 9, 2012 | 12:49 PM
Atomic's Avatar
I have a gauge for that
its on any time the fuel pump should have power...so for a few seconds with key in run with engine off and all the time with the engine on.
Old Mar 9, 2012 | 02:00 PM
skeet's Avatar
thanks, thought so just wasnt sure!
foot note: theres also a 15 amp fuse next to the fuel pump relay, if your pump all of a sudden quits working check that fuse first, i almost made the mistake of buying another fuel pump until a good friend told me about that fuse
Old Mar 3, 2025 | 12:52 AM
emi165's Avatar
Registered User
That's the wire going to the fuel pump, but the actual trigger wire for the relay is the green and white one
which color wire is the signal/trigger wire on the pump connector itself? 04 silverado 1500
do you have a photo?
Old Mar 3, 2025 | 09:19 AM
MikeGyver's Avatar
Originally Posted by brandon_6667
... so I ended up finding other threads saying it's the grey wire coming out of the harness ....
Maybe you skipped over the Brandon post
Old Mar 3, 2025 | 09:22 AM
MikeGyver's Avatar
The power, ground, and fuel level sensor are in the pump harness. The signal wire goes from the PCM to the relay.
wrb002
Aug 31, 2015 12:00 PM
slowlsx
Aug 13, 2015 08:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
