where is the fuel pump relay trigger wire?
cool, thanks for the info. I will probably just keep an extra relay in the glove box just in case, and will keep in mind to check the factory relay first if I ever have a problem.
You don't need to carry an extra relay. If you ever suspect a bad fuel pump relay, just swap the a/c relay or horn relay into it's place. They are the same part, and in the same electrical center. Makes it really easy!
foot note: theres also a 15 amp fuse next to the fuel pump relay, if your pump all of a sudden quits working check that fuse first, i almost made the mistake of buying another fuel pump until a good friend told me about that fuse
slowlsx
Aug 13, 2015 08:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
