weird pop coming out of exhaust
well i checked the valve springs those are fine i got those junk msd wires they dont even feel like there on the spark plug good enough might just buy some 10mm wires to see if that fixes it when it revs up its fine those its more like a little soft pop
well still having the problem put some new wires on didnt fix it i think i sucked something up and its clogging my injectors so im going to run some injector cleaner threw it hopfully that fixes it if not straight to race fuel
well im getting sick of this frigin problem its driving me nuts i think its that walbro fuel pump i did run it down past 1/4 tank maybe that was the problem burnt the pump and that was the first time ive done it and now this
Fuel pump doesn't make since if its only poping at idle. If you had popping, chugging, or just wanting to shut off under acceleration or anything off idle I would then check out the fuel system. But your only having issues at idle. So I would rule out Fuel pump.
Your computer can't just forget what tune you used and then guess at how to start and run your truck so I would put tuning out of the question. I woudn't worry about tuning issues unless you changed your tuning and THEN started having problems.
I would check out your leaky y-pipe. Its the simplest to fix out of the above listed. Just loosen up and re-tighen. If that doesn't work and it still leaks pick up some O2 sensor safe RTV and make a better gasket. I would recomend working on a cool or cold exhaust and letting the RTV (if needed) to dry over night or at least for a few hours before testing it out.
V-seriesTech
07-28-2015 12:31 PM
