weird pop coming out of exhaust
Old Mar 9, 2010 | 05:06 PM
droppedchev's Avatar
Default weird pop coming out of exhaust
i started up my truck yesterday and it was popping pretty bad dont know what it could be no light or anything only at an idle reving up is fine anybody got any ideas
Old Mar 9, 2010 | 05:09 PM
SSlow 4.8's Avatar
stuck valves/broken valve spring?
Old Mar 9, 2010 | 05:11 PM
yea thats what im thinking im going to check tomorrow
Old Mar 9, 2010 | 05:12 PM
i checked all the plugs fuel pressure everything checked out good so im to pull the covers to see if theres something broken if it is you think the valve could be messed up
Old Mar 9, 2010 | 05:16 PM
SSlow 4.8's Avatar
not sure... anytime ive ever had a popping noise in the exhaust, one of the valves were stuck. Might not be valve damage, possibly just a valve spring and/or roller rocker.
How consistent is it? Can you even drive it?
Old Mar 9, 2010 | 05:17 PM
00ChevyScott's Avatar
Wearin' da big hat
Do you have a wideband for when you're spraying?
Old Mar 10, 2010 | 05:40 AM
yeah i have a wideband and it seems fine when i rev it up its only at an idle when its popping and yea i can drive it to just weird
Old Mar 10, 2010 | 06:14 AM
JakeBrakeIH's Avatar
Does it only pop on the decel after you rev it?
Old Mar 10, 2010 | 02:31 PM
nope its only popping at an idle when its cold it really pops
Old Mar 10, 2010 | 03:47 PM
brent1976's Avatar
11 Second Club
Check your plug wires. Mine did this for about a month before I figured out that the rubber insulation on the outside of the plug wire was burnt, but nothing else was. I just happened to see it arching in the dark on night. It ran fine, but had a very random, and quiet backfire at idle.
