Vortec 350 wont start
Old Dec 21, 2006 | 04:54 PM
JohnnyStorm's Avatar
Default Vortec 350 wont start
Made a round trip of 700 miles and filled up just 7/10ths of a mile from home, parked it for the night and the next morning tried to start it and it just cranks. I checked for DTC's and there are none. I checked for spark and I have it coming out of the coil very well. When I go to KOEO I can hear the fuel pump prime. So I can eliminate the ICM and coil (I actually bought a new ICM) Ouch! The plug wires, cap and rotor are all replaced by me including the coil (Accel). I bypassed the Accel Ignition box and eliminated that also. I don't think it's the PCM as that drives the ICM which turns on the coil which I have spark to and the PCM gets signals from the distributor so I think the ignition is OK.
Is there anyway to verify the fuel system since there is no schrader valve to attach to on this "96" K1500. Like I mentioned before I can hear the fuel pump prime.
Thanks in advance.
Old Dec 21, 2006 | 05:03 PM
Bo185's Avatar
Could be just a stopped up fuel filter.
Old Dec 21, 2006 | 05:20 PM
Dock Rocker's Avatar
Yea change the Fuel filter and see if that is it.
Old Dec 21, 2006 | 06:45 PM
I changed it back in May so I was reluctant to do that, but...
As cheap as they are it really couldn't hurt. Plus I can see if gas is being pulled from the tank. I actually hope it's not the pump as I have 25 gallons of gas in the tank. I will try it and let you guy know if it works.
Old Dec 22, 2006 | 01:48 AM
Typically they fail after a fill up.
Its a truck unbolt the bed,sit it back on the tires and change the pump from the top.
Old Dec 22, 2006 | 03:12 AM
James B.'s Avatar
This happened to neighbor's 1997 Suburban. He called me over listened to it crank. Fuel pump sounded weak so tested pressure and found it low. I told him to get a fuel pump. He did and I put it in for him. That was it.
Old Dec 22, 2006 | 04:07 AM
James,
Thanks for the info. Last night I pulled a plug and it was wet with gas, not fouled at all. I checked to see if the spark was getting to the plug by grounding to header and I have ample spark. I figure if I'm getting fuel and spark I should be able to start. I just checked the PCM by using my JET Tuner software to read my PCM, so I think I've eliminated that. I do have a new fuel pump for it that I had bought and I guess this is a good time to install it. But I still have a feeling something else is going on.
Qustion:
If I have a oil pressure sensor failure would this cause a no start situation?
I'm betting this would set a DTC.
Also, I noticed my milage on the return trip was less.
Old Dec 23, 2006 | 01:48 PM
Dirty Dave's Avatar
There is a schrader valve follow the fuel lines back it is under the plug wires.
Old Dec 25, 2006 | 12:47 PM
You are right. I completely overlooked it. Well guys I've changed the fuel filter and as soon as I get a fuel pressure guage and take a reading. I will know if the fuel pump is going to be swapped. Because of the Holidays I have had to put this on hold till later.
Thanks to all and have a great xmas.
Old Dec 26, 2006 | 05:48 PM
Ok. I got a fuel pressure tester and tested the pressure in the KOEO position at the schrader valve and had 62 psi initially and then dropped to 57 psi and stayed there.
James B. - Do you still think it's the fuel pump?
