very little bottom-end after tune ???
Old Jun 3, 2010 | 11:10 AM
  #41
BigRed Cummins's Avatar
Just out of curiosity, you said that it as a lack of power after the tune. So, did you install the cam and tune it on the same day, or did it haul ****, and then you had it tuned and now it is gutless? Because I am also starting to lean towards a cam that has been installed too far advanced, but only if it was slow after the cam swap. Also, like I said, you need to look into the problem of the sensors asap, either fix the problem that is causing a bad reading, or replace the sensor, whichever the case may be.
Old Jun 3, 2010 | 12:51 PM
  #42
silverado2000's Avatar
no the tune is not the issue. i was just saying i went and got it tuned the day i made this post and he told me i may have a weak fuel pump. the cam and motor were put in back in nov. 09, the truck has never ran right. allen has done his best to make the truck drivable for me. it has ran better though then it just got worse. it use to spin the tires at 55mph (real crappy tires there always funner). I hope when i trade all my coils, maf, and change the knock sensors this sunday the truck will stop pulling timing.
Old Jun 3, 2010 | 12:55 PM
  #43
Atomic's Avatar
I have a gauge for that
it might be worthwhile to have a compression test done on all cylinders to rule that out
Old Jun 3, 2010 | 01:03 PM
  #44
im doing that to this weekend.
Old Jun 3, 2010 | 11:48 PM
  #45
9 Second Club
Changing the maf and the knock sensors wont help if they have been turned off in the tune.
Old Jun 4, 2010 | 12:38 PM
  #46
im doing it for when i re tune it
Old Jun 8, 2010 | 12:58 AM
  #47
ok so this weekend i put my coils off my truck on my brothers truck(2003 z71 5.3), and the truck had a slight miss, his truck didnt show any codes though, how bad can a truck run with a weak coil?
Old Jun 8, 2010 | 02:21 AM
  #48
Dewey's Avatar
usually it gets worse at higher RPMs from what i've heard.
Old Jun 8, 2010 | 05:48 PM
  #49
yeah on his truck it seemed to get worse as the rpms went up.
Old Jun 12, 2010 | 09:33 PM
  #50
zo6pilot's Avatar
It sounds like operator error.I bet my 5.3 could beat your truck to 155 with my eyes closed on a Diablosport tuner and my LT's...That is weak but can beat a NNBS 4.6 GT. Fix your truck then go to a tuner.Your episode is weak.I will trade you your "free tune" for Nelson's redone anyday! Farmtruck I'm ready!
Rob
