very little bottom-end after tune ???
Old May 24, 2010 | 08:09 PM
silverado2000's Avatar
Default very little bottom-end after tune ???
went and got my truck tuned to day and it has very little power below 3000rpm. it has trouble getting off the line, i was told it might have a weak fuel pump. has anyone had troubles with a weak fuel pump or had trouble with getting low-end power out of there truck? the trucks the exact same as everything in the sig.
Old May 24, 2010 | 08:46 PM
wentbig's Avatar
your tune sucks re do it
Old May 24, 2010 | 09:40 PM
It's the fifth tune on the truck sence nov.
Old May 24, 2010 | 10:01 PM
PathfinderJr's Avatar
you been getting it tuned with the same tuner?
Old May 24, 2010 | 11:09 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You have a tuner issue, sir.
Old May 24, 2010 | 11:22 PM
Jeteys5.3's Avatar
Wheatley is in your area somewhat, you should contact him for a tune
Old May 25, 2010 | 02:52 AM
i was thinking of trying them. just wanted to give the guy im using a chance. so no one has had issues with a ground or anything messing with only the bottom end power? i know its a long shot i just hate to think im gonna have to have it tuned again.
Old May 25, 2010 | 10:32 AM
Truckshop's Avatar
you have a cammed 6.0 with a 3600 stall and have problems getting off the line? that doesnt make any sense. you may need to look into a new tuner. it should blow the tires at speed under 20mph.
Old May 25, 2010 | 01:02 PM
that is what im sayin. so everyone thinks its the tune? well guess its time to find a new tuner and see if that changes it.
Old May 25, 2010 | 05:40 PM
Truckshop's Avatar
there could be other issues but if your tuner cant tell you whats goin on then i suggest you look elsewhere. i tuned a camaro that was a turd no matter what i did to the tune. but after looking at some data the mass air was bad. should have seen the smile on the guys face after he replaced it.
