Tuning a turbo vortec 5,3
Old Dec 1, 2009 | 11:37 AM
Breth's Avatar
Registered User
Default Tuning a turbo vortec 5,3
Hi!
Im planing to turbocharge my 2002 silverado 5,3.
I wanna run 7-8psi of boost. Im looking for 400-450hp (on the flywheel)
I know i have to get:
Turbo, wastegate, intercooler, maybe bigger injectors and a bigger fuelpump.
I saw on the STS-kits that they have the diablo predator tuner.
My question now: Can i tune fuel and boost only with the predator tuner??
Best regards from switzerland Breth
Old Dec 1, 2009 | 12:33 PM
Coban's Avatar
Im assuming you meant to say 7-8 psi of boost. That power level can easily be accomplished at that boost level.
You will definitely need:
Larger injectors - 42lb/hr can be used, but look for 60's while you are at it.
Intercooler
Wastegate
Blow Off Valve
Turbo + piping
Oiling provisions
And of course your tune. Its not the preferred way to do it, but according to the predator site, you can adjust injector size. The boost tuning might be more difficult.
There are better kits out than STS and better tuning solutions... I recommend that you look around the forced induction section.
Old Dec 1, 2009 | 01:36 PM
Breth's Avatar
Registered User
Oh yeah sorry! i meaned 7-8psi
So does that mean that with the predator i dont can tune the car when it got boost? So do the electronic only reed the air flow sensor to give more fuel when under boost?
Old Dec 1, 2009 | 01:38 PM
charcold-bowtie's Avatar
Maf reads airflow, not boost.
Sounds like a Mail order tune would be your best bet.
Old Dec 1, 2009 | 01:55 PM
Breth's Avatar
Registered User
Is ther a computer i can plug in in the obd2 and then can tune all fuel with using a mapsensor for boost
Old Dec 1, 2009 | 02:08 PM
Yes, your stock one. Look into Efilive. They also have a good tuning forum
5.3lSilverado
25
Aug 29, 2016 12:48 AM
Ls3silverado
Jul 31, 2015 04:22 PM
oharajo
Jul 18, 2015 09:24 PM
4B11T
Jul 13, 2015 03:48 PM
