Tuning around battery voltage changing
Old Jun 30, 2014 | 11:53 AM
timmay208's Avatar
Well today i was told that is my tune thats the issue, my VE map is not right, and my power enrich is not setup correct
I still dont think that has anything to do with it but im not a professional tuner by any means
Old Jun 30, 2014 | 01:05 PM
timmay208's Avatar
found this under system
"alt F term" it has a 1 on it, i wonder if that has to do with charging system
here is more info on it
http://www.archivedsites.com/TECH_CO...05%20Final.pdf
Old Jun 30, 2014 | 02:48 PM
oakley6575's Avatar
If you could post screenshots of those tables, the FIC data and the data you entered in your tune, I could help you out. I've tried to open your tune but it won't download for some reason.
Old Jun 30, 2014 | 03:00 PM
timmay208's Avatar
i cant paste exact numbers, when i enter them its like it rounds it to the closest number
also i found this thread
https://www.performancetrucks.net/fo...-488787/page2/
going to look see if mine has that on the neg cable or not if so i may just unplug it
Attached Thumbnails Tuning around battery voltage changing-injectordata.jpg   Tuning around battery voltage changing-offsett.jpg
Old Jun 30, 2014 | 03:03 PM
03sierraslt's Avatar
Based on your offset table, your injectors have a slow response time. I thought those injectors were faster. Post up your data for them that they came with. My Alt L Term and F Term has a 1
Old Jun 30, 2014 | 03:05 PM
timmay208's Avatar
i already posted the data here in the thread, its a download link cause the forum wont let me load it in my post
only 05+ trucks got the RVC systems, im just trying to figure out if there is a way i can disable it and make it sit at 13.8 as if it was in a "fail mode" cause i have the feeling trying to tune around the voltage change is going to be a bitch
link for injector data
it wont let me attach the excel sheet so heres the link
http://www.filedropper.com/fic873cc83lb4barev14hptrev01
Old Jun 30, 2014 | 06:15 PM
Suburbazine's Avatar
You don't have the ammeter clamp on the negative cable? Should just unplug it and be done with the wandering voltage. I think the only downside to this is that clamp also has a backup battery for the radio/presets in the event the main battery runs dead.
Old Jun 30, 2014 | 06:24 PM
timmay208's Avatar
i dont remember ever seeing anything on the neg cable, im going to look after work though. From what i read some is a deal on neg cable, others is done by computer
Old Jun 30, 2014 | 08:49 PM
timmay208's Avatar
ok so i did have the plug on the neg cable, unplugged it and stays at 13.6v, however that leaves my battery light on
Old Jun 30, 2014 | 08:59 PM
oakley6575's Avatar
Time for an custom autometer gauge cluster
