tune trouble
Old Apr 17, 2009 | 09:25 PM
southern_chevy's Avatar
Default tune trouble
Well here lately I have randomly been having a real lean condition that will make the truck fall on its face for a really short time and then pick right back up. It does it at cruising speed and does fine at wot. I logged a little today and it showed the ect going from 203 to 46 could the ECT sensor be going out and causing this? Here is a screen shot.
Old Apr 17, 2009 | 10:49 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
bizzare....bump for ya!
Old Apr 17, 2009 | 10:56 PM
nonnieselman's Avatar
is there any codes in the PCM?
seems like its goin to be the ECT sensor, or a bad connection.
if you look at your tune, when your ECT is that low its goin to be rich. i see your Commanded AFR is 11.7 at 32% throttle.
Thats your problem..
Try to disconnect the ECT sensor and check for any corrosion or anything.
Old Apr 18, 2009 | 06:16 AM
Glad you cought that I will check the sensor and/or change it this afternoon and see if it changes anything.
Old Apr 18, 2009 | 06:28 AM
viciousknid's Avatar
Where's the Beef?
You went lean but your IDC went Up?
ECT sensor could be bad, wouldn't hurt to change it. Cant cost much.
Old Apr 18, 2009 | 06:42 AM
The wideband pegs rich first then swings back lean. I am going to change it and see if it helps or stops it.
thunder550
Oct 8, 2015 04:53 PM
MWRitter
Jul 27, 2015 09:41 AM
lxcoupe
Jul 21, 2015 02:12 AM
