Idle surging after driving then dies
My truck has all the bolt ons, 220 cam, 9.5 3800 stall. The problem started after the converter got put in a few months ago. The truck will start surging(rpms start to jump up and down) real bad and will want to shut off if i do not put it in neutral and give it a little gas. It will only do it after i drive for a while with out a lot of stop and go, like if i get on the interstate and drive for like three exits and then get off and stop at a red light. It will also do it if i pull in a parking spot and give it a little gas and let of quick to hit the brake. I also noticed sometimes while waiting in traffic it will start to surge for about 30 seconds and then stops.
I had a friend raise the base running air flow but when i start the truck it flares up to 2500 rpm then back down. It helped a little but there has to be a better way to fix it. I am going to get the file, i do not have it right now.
Thanks for any help
KyleM
Thanks for any help
KyleM
After a cam swap to get the car or truck idling on it's own I add 2-3 g/sec to the whole idle airflow table for starters then I tune the ve and maf to get my trims within 3% and then do some RAF tuning which takes a little time and patience if you want to do it right and have a good idle.
Here is the thread my friend started on HPTuners forums. The file is on the first post. http://www.hptuners.com/forum/showthread.php?t=23013
Not yet i have not got back down to Orlando.
Thanks
Thanks
