tune trouble
Well here lately I have randomly been having a real lean condition that will make the truck fall on its face for a really short time and then pick right back up. It does it at cruising speed and does fine at wot. I logged a little today and it showed the ect going from 203 to 46 could the ECT sensor be going out and causing this? Here is a screen shot.
is there any codes in the PCM?
seems like its goin to be the ECT sensor, or a bad connection.
if you look at your tune, when your ECT is that low its goin to be rich. i see your Commanded AFR is 11.7 at 32% throttle.
Thats your problem..
Try to disconnect the ECT sensor and check for any corrosion or anything.
lxcoupe
Jul 21, 2015 02:12 AM
