tune put on engine light!!!
Old Mar 15, 2006 | 03:41 PM
houstontxtravis05chevy's Avatar
Default tune put on engine light!!!
whats goin on yall,
I got a tune for my 05 silverado and it turned on the engine light. i got it checked out at autozone and they told me the codes its puttin out...
p0172-system too rich bank 1
p0175-system too rich bank 2
p0315-crankshaft position system variation not learned
p0315- "
if you know how to get these off or have any suggestions please write back
thanks very much,
travis
Old Mar 15, 2006 | 04:07 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
315 just means you need to go to the dealer and get a crank relearn done takes all of 5 minutes no big deal. Who tuned it?
Old Mar 15, 2006 | 04:19 PM
Default replyyyyy
me and one of my freinds ordered it from some guy out of state...i went by a couple places and nobody knows how to get it off
Old Mar 15, 2006 | 04:31 PM
1slow01Z71's Avatar
dealer tell them you need a crank relearn
Old Mar 16, 2006 | 01:31 AM
Post
Should of used Allen Nelson!!! Then you wouldn't be having these problems.
Jim
Old Mar 16, 2006 | 04:39 AM
BillnLA's Avatar
Anyone with a newer scan tool, such as a Tech 2, Genisys and Snap-on can do a crank position relearn. As posted before, only takes a few minutes to get it done. It doesn't have to be a dealer. You should only have gotten that code if you changed out your PCM to one that wasn't stock. My tuned PCM is sitting in the box, it just came in on the 15th. Won't get a day off for a couple of weeks to be able to install and get the relearn done. There should be a number of places in the Houston area that can do this. Good luck.
Old Mar 16, 2006 | 12:22 PM
Post
I have access to a Genisys, but not really too sure how to do a crank relearn with it.
I can scan, read codes, and do real time read outs. I can also make it do specific tests, but never seen anything about crank relearn.
I'd help the guy out, but I would need help helping him.
Inform me.
Jim
Old Mar 16, 2006 | 10:57 PM
1slowsilverado's Avatar
Inform me.
Jim
How updated is your Genisys? Worst 3k I ever spent! I will have to wipe the dust off and check. But if you Select the make, model, etc.. Go under Special Tests and it should be in there.
ARC
57
Feb 21, 2022 10:54 AM
tweeder
Sep 18, 2015 11:02 PM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
hackrst
Jul 11, 2015 11:17 AM
