Trucks Runnin' like Crap
Old Aug 9, 2008 | 10:05 PM
  #21
sprayed8's Avatar
i don't think my tuner would have a problem with posting up my tune so here it is.
i have messed around timing, shifting and DFCO and i have made a little progress and the truck def. feels stronger. i havent touched my MAF or VE yet because if my exhaust leaks are causing the problem then there is no point in trying to tune the fueling cause it wont be right anyway.
File Type: hpt
Old Aug 9, 2008 | 10:17 PM
  #22
charcold-bowtie's Avatar
Im not too smooth with hptuners yet. But what is up with your PE settings.All zeroed out. Seems to me it would be in PE all the time runing at 1.130 or whatever it was. Hmm i dunno hp tuners is so different, the tabbing anyway
Old Aug 9, 2008 | 10:43 PM
  #23
mcfarlnd's Avatar
Un-Registered User
if you know for sure you have exhaust leaks i would fix them first before trying to troubleshoot anymore. and charcold-bowtie is correct about the pe. put em back to stock for the time being.
Old Aug 9, 2008 | 10:45 PM
  #24
sprayed8's Avatar
The way i read it the only deciding factor as to when i'm in PE is my TPS, and when i am its always at 1.130.
Old Aug 9, 2008 | 10:51 PM
  #25
trever1t's Avatar
2nd fastest 5.3 ECSB
Shouldn't the OL EQ tables match? ah, never mind, I'm tired.
Old Aug 9, 2008 | 10:52 PM
  #26
mcfarlnd's Avatar
Un-Registered User
do you have 4.10s?
Old Aug 9, 2008 | 10:58 PM
  #27
mcfarlnd's Avatar
Un-Registered User
your tps is at 90% 0-2400rpm and 50% beyond that for hot
and for cold it is 90% 0-3200 and 50% beyond that.
Old Aug 9, 2008 | 11:05 PM
  #28
sprayed8's Avatar
yeah i have 4.10s.
not sure if it matters but this was a WOT tune only.
I dont really know but i dont think it matters if the OL Eq. tables match because they are both 1 across the board around operating temp right?
I dunno i'm still pretty in over my head so far
Old Aug 9, 2008 | 11:07 PM
  #29
mcfarlnd's Avatar
Un-Registered User
under pe enable hot and cold change those to 90%
Old Aug 9, 2008 | 11:09 PM
  #30
mcfarlnd's Avatar
Un-Registered User
i would match the eq tables.
