Trucks Runnin' like Crap
Old Jul 4, 2008 | 05:23 PM
sprayed8's Avatar
so i'm ordering HPTuners as soon as the bank opens and i can deposit some money in my account but for now more questions.
i changed the manifold gasketsand the truck seems to be running a little better. however, here are my problem areas.
If i take off slow from a stop/low speed roll and then get on it it feels fine (a little sluggish, but not bad) but if i whack the throttle even at like only 15% throttle it bogs (kinda stutters actually) and then pops and bogs until i let off the gas and then i can hit it again and its fine.
Could an exhaust leak cause it only to bog at very low speeds. Acceleration Enrichment was mentioned in another thread? Maybe Knock?
Any ideas would be great.
Old Jul 4, 2008 | 10:46 PM
brent1976's Avatar
11 Second Club
When I first put on my lts my truck would pop very randomly at low rpms (under 1500), and be sluggish from a stop. Mines got a cam so I didn't see any missfire, but I noticed a plug wire being blistered from the headers.
That was my whole problem, one plug wire.
Old Jul 6, 2008 | 02:41 PM
sprayed8's Avatar
thanks for the input, i am beginning to think that they are the only reasonable solution since the only things i touched when i did the install was the intake tube, header gaskets and the plug wires. so far i have changed the gaskets and triple checked the intake so the plugs are suspect.
Old Jul 6, 2008 | 06:12 PM
tarinitup's Avatar
9 Second Truck Club
The poping at low rpm's and light throttle sound like it's rich to me. I am experiencing severe richness after a cam swap and it sounds just like what you describe. Get some kind of scanner to check the fuel trims and see if the pcm is adding or taking away fuel after you check the plug wires.
Old Jul 8, 2008 | 01:37 PM
sprayed8's Avatar
ok so i FINALLY ordered HPTuners tis morning, but now i hafta wait at least a week but that cant be helped.
so when i do get it, i am gonna be am major newbie so...
What should i look for to tell if its goin rich at low rpms if i do not yet have a wideband.
Old Aug 3, 2008 | 10:22 PM
sprayed8's Avatar
HP Tuners is finally up and running and it looks like my fuel trims are adding a lot of fuel all the time. my long terms are almost always above +8 but often at 15+ and the short terms fluctuate... usually the lower the long term, the higher the short term. i will post up a log from my drive to work in the morning.
Old Aug 4, 2008 | 05:45 PM
brent1976's Avatar
11 Second Club
Did you try new plug wires? That's what mine did only my trims went to 20 sometimes.
Old Aug 4, 2008 | 07:18 PM
sprayed8's Avatar
Yeah i got new wires and so no effect unfortunately. this will be the first time i have posted a log so how long of a log can i post up? i have one of me driving around thats like 7 minutes.
Old Aug 4, 2008 | 07:26 PM
sprayed8's Avatar
ok lets see if this works.
File Type: hpl
Old Aug 9, 2008 | 07:10 PM
mcfarlnd's Avatar
Un-Registered User
will your tuner allow you to post up a tune? if not thats fine. when are you gonna put the w/b in? have you scaled the maf and ve tables yet?
