trouble code P0332 robbing power?
Old Nov 13, 2006 | 10:58 AM
ramair383ci's Avatar
I took me about an hour to put the new senors in. On the second day of using the truck I got on it from a dead stop until I hit 85mph and the service engine light went away. I can feel the truck much more responsive on take offs more torque and thats that I reset the ECM a couple of times before I was 100% sure it was the sensor and not something else so its still going through the fule learning curve. All and all I'm so happy that it was a simple fix and that darn light is not on any more.
Old Nov 14, 2006 | 10:18 PM
blake2kz71's Avatar
well il put everything back togethar tomorow and hopefully it fixed mine. i siliconed the **** out of em so it shouldnt get anything else in it. the one in the back of the valley cover had water, dust, grease and all kinds of **** in it so i cleaned it out good and put the new sensor in. thanks for all the info it wasnt near as bad of a job as i thought it was gona be. helluva sat. night though.
Old Nov 22, 2006 | 09:52 AM
I am having a prob with my truck pulling timing out (knock retard) in 2nd gear above 4000 rpms. Does anyone think that i might need to change the sensors or maybe something with the tuner. I have the predator u7195 on it on performance tune. Ported tb, coolant bypass and cat back and a k&n drop in filter. no other mods
Old Nov 22, 2006 | 10:35 AM
Mort's Avatar
Cool
If you are experiencing this at high TB angles over say 80% it might be from TCC lockup. I was finding that at WOT runs I would start to get KR at the top of first and then higher KR all through second and then less after the shift to 3rd. I modified the lockup table in 2nd so that it will not lock up at all in 2nd and the KR is gone and the TCC locks up after the 3rd shift but it does not seem to cause any KR. I have only logged a couple of runs since I made the change but it seems to be working. No more KR.
Thanks to Holty for the idea I think.
Old Nov 22, 2006 | 03:42 PM
I cant modify that with the predator can I?
Old Nov 23, 2006 | 09:43 AM
Mort's Avatar
Cool
No I don't think that the predator can help with that but I am not sure. Can you set your TCC lockup speeds with the predator? If you can set your 2nd gear lockup to 255mph for all throttle positions. That will keep it from locking up in 2nd gear.
If the predator will not do it you will need tuning software to make the change.
ARC
57
Feb 21, 2022 10:54 AM
Corvette454l88
Sep 1, 2016 01:24 AM
thunder550
Oct 8, 2015 04:53 PM
JFortner5
Aug 19, 2015 02:44 PM
blownss27
Aug 14, 2015 03:31 PM
