TrickPerformanceProducts new wideband special
Old Jan 27, 2009 | 02:45 PM
TrickTurbo's Avatar
Truck Sponsor
Default TrickPerformanceProducts new wideband special
We are accepting PRE-orders on our new wideband.
The unit retails @ 199.00 includes bosch sensor.*
Special preorder pricing is 189.00 + freight
339.00 include NTK sensor. needed for race gas.
Special preorder pricing is 329.00 + freight
!!!!GROUP SPECIAL 10 or more FREE FREGIHT!!!
This unit is very compact (4.5 x 1.4 x 1.25) and can be mounted just about anywhere. Water tight construction means all weather conditions, and not worring about it getting wet. Sensor comes with a 18" lead that plugs directly into the controll box. Extention cables are available for more reach if needed
Features:
• Accuracy better than 0.1 AFR over the range 10.5:1 to 15.5:1
• Sampling rate greater than 250 per second
• 2 channel Analog outputs. Set for the most common air fuel curves.
• 0v out = 7.35:1 a/f 5v out = 22.37:1 Linear Output & 0.5-4.5 10-20 air fuel ratio.
• Replaceable sensor harness
• -40° to +85°C [-40 to +185 °F] ambient operating temperature range
• Available wideband LED gauge.
• Multi-sensor support (NTK and Bosch sensors)
• High speed Digital Data Bus for interfacing with Trick V and P gauges.
• Seamless integration with other Trick products
• Built for the racing environment to withstand heat, vibration, dirt and water
• Free direct technical support
PM me if your interested in the specials.
Rick
Here the pic of the complete set up.
* O2 bung adds 3.00 to the kits price.
Old Jan 27, 2009 | 02:57 PM
kbracing96's Avatar
Serial output?
Old Jan 27, 2009 | 03:03 PM
00ChevyScott's Avatar
Wearin' da big hat
How hard would it be to hook this up to an AFR gauge?
Old Jan 27, 2009 | 03:17 PM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by kbracing96
Serial output?
Not for what you thinking. LOL The serial wire is for Trick Wideband gauge only.
Depends on the gauge. The Wideband has dual analog outputs. There are 2 other outputs, both are for interfacing with other Trick Products.
So if your gauge uses an anolog input voltage 5 or less just need to know the curve its looking for.
Rick
Old Jan 28, 2009 | 03:55 PM
TrickTurbo's Avatar
Truck Sponsor
bump.
Old Jan 29, 2009 | 09:14 PM
WJ MARK's Avatar
how much extra is the guage???
Old Feb 2, 2009 | 08:21 AM
krambo's Avatar
So this will be a plug and play for the Trick Nitrous P-gauge's Wideband function?
Old Feb 2, 2009 | 09:54 AM
TrickTurbo's Avatar
Truck Sponsor
Yes this unit will plug into the V or P gauges. I have to know that is what you are planning, there is a jumper lead/termination lead I have to included. All weather pack just plug and go.
Here are the instructions for the unit.
Stand alone LED gauges will be 100.00 ish, waiting on them to come in to confirm all freights etc.
Rick
Old Feb 5, 2009 | 04:19 PM
TrickTurbo's Avatar
Truck Sponsor
With gauge kit, including sensor would be 275.00... All parts have to be purchased at the same time for this great deal...
SS94S10
Jan 3, 2019 01:57 PM
69z-28
Sep 21, 2015 07:31 AM
FlowmasterMufflers
Sep 18, 2015 02:31 PM
TrickTurbo
Sep 10, 2015 11:46 AM
madmann26
Sep 6, 2015 04:19 PM
