traction control function problem
Old May 7, 2014 | 08:57 PM
02gmcbandit's Avatar
Default traction control function problem
For some reason the Traction Off light is staying on .I've unhooked it and connected it back.unhooked the battery and even bought a new switch and tried it anf its the same thing. It says its off but time the truck spins it flashes Low Traction and kills the power. What controls the switch for me to check? Is it a relay or what? I have 4:56 gears and it spins easily and keeps killing the power which gets old. Its a 2002 sierra. Any help would be greatly appreciated
Old May 7, 2014 | 09:18 PM
1FastBrick's Avatar
Custm2500's Rude Friend
When did this problem start?
Old May 8, 2014 | 05:34 AM
A while back I've just never been able to fix it. I was doing an led install in the switch when it happened which was why I thought it was the switch but I've changed it to a stock one and still didn't help. The function works far as the truck spins and it kills the power but I have no way of turning it off since the button isn't working
Old May 13, 2014 | 02:03 PM
And this is why it is still broken lol. No one knows anything about the switch??? It has to get signal from something?? Trans? Sensor? Relay?
Old Nov 5, 2014 | 09:59 AM
Bump, any thoughts on what could control it?
Old Nov 5, 2014 | 11:23 AM
1FastBrick's Avatar
Any engine codes stored?
Did you get re tuned for the gears?
Old Nov 5, 2014 | 04:31 PM
Nope no codes, and not yet, trying to wait until after my stall to go get retuned
Old Nov 5, 2014 | 04:38 PM
1FastBrick's Avatar
Thats why. It sees a mismatch in wheel speed based on the gears programed in the pcm. You swaped the gear ratio and it doesnt add up. I bet if you scanned it with a more indepth scan tool it would show something under the abs module.
Old Nov 5, 2014 | 04:53 PM
The abs controls the traction control? If its as simple as the tune I'll put my stall in asap and get retuned, I've had it sitting around for forever but didn't want to put it in until I got this issue fixed.
Old Nov 5, 2014 | 06:03 PM
1FastBrick's Avatar
Yes, the traction control system reduces wheel spin by applying the brakes using the ABS pump. I know that it does calculations based on transmission output shaft speed and wheel speed based on the Tire size and the Gear Ratio programed into the PCM.
On a friends truck, his tuner forgot to change the gear ratio and it went into limp mode. But it's an 03-05 style truck and the electronics are a little different.
