Tips for Dynoing
Old Nov 14, 2005 | 11:30 AM
YenkoST's Avatar
Default Anybody got tips for dynoing????
Just wondering if anyone had any tips for dynoing. I am going this coming up Sunday and just wondering what I should be looking for, have to do at the dyno, and doing to the truck to get it ready. Thanks for the help.
Old Nov 19, 2005 | 09:46 AM
YenkoST's Avatar
anybody??
Old Nov 19, 2005 | 11:00 AM
Zick's Avatar
Not sure what kind of help your looking for really. Basically when I did mine, I just made sure I had some good gas in her and they straped it down and ran it.
Are you just getting a dyno run done or are you tuning it too?
Old Nov 19, 2005 | 12:39 PM
YenkoST's Avatar
Just dynoing it. I did the following today, checked oil, tranny fuild, coolant, and a couple of other things. Anything else I need to look at?
Old Nov 19, 2005 | 06:49 PM
Crash Dummy's Avatar
Former Moderator :(
Tip # 1 If it catches on fire RUN
Tip # 2 If it blows up CRY
Tip # 3 If it doesn't make power Dont Tell anyone
Tip # 4 If it makes to much power Blame the dyno
Tip # 5 If everything goes well Tell everyone
Old Nov 19, 2005 | 10:24 PM
CHarris's Avatar
You forgot the addendum to tip #3... sell the truck like nothing is wrong and disappear off the forum...
As some may notice, This closely echoes the tips for making a lot of power and then breaking parts so that the truck is undriveable.
Old Nov 19, 2005 | 10:58 PM
wkdivr's Avatar
That's great!! Crash, by the way, check my sig!! Did it last Sat.!!!
Old Nov 20, 2005 | 05:51 AM
YenkoST's Avatar
Thanks for the help I guess guys!! I will see what it does today!!
Oh by the way, if it doesn't put down the numbers I want.......then there's only one alternative for me......add more power!!!
Old Nov 20, 2005 | 08:08 PM
BlownChevy's Avatar
blownerator
25 Year Member
Update?
Old Nov 20, 2005 | 09:52 PM
GMC_DUDE's Avatar
With the smartdonkey responses everyone gave him, I'd be surprised if he ever comes back. YenkoST, if you are still out there, sorry I didn't see your post earlier, but here are some tips:
Make sure the engine is thoroughly warmed, so that you're not running in "cold engine" (old fashioned "choke is on") mode.
Have the operator either dyno it in 2nd gear, or if they refuse, then in 3rd gear. The fewer shifts the better.
Make sure they are monitoring AFR during the dyno. Sometimes they forget, but the info is invaluable.
Make sure they do all the runs you are paying for, and that they give you both a graph and a table printout for each run.
I see from your sig that you apparently don't have FI, but if you add it later, have them blow some cold air over the intercooler, or fill the coolant reservoir with ice, or do what is necessary to get the IAT temps down. One large source of discrepancy between the dyno and the street is that on a dyno the vehicle is stationary, so the intercooler is ineffective.
Hope some of this helps for any subsequent dyno tests. Again, sorry I was too late.
