throttle cracker efi
Old Feb 11, 2009 | 04:35 PM
viciousknid's Avatar
Where's the Beef?
Default throttle cracker efi
I believe the throttle cracker is what needs adjusted for this scenario. I have the idle right where I want it. But when I go to take off, If i'm pulling out of a parking spot or something, I give it the gas and let off and it dies. It's like it just tries to drop the rpms too far after I let off.
Anyone have any tips on how to get this adjusted right?
Old Feb 11, 2009 | 04:38 PM
Where's the Beef?
I should say. when I let off, the rpms drop, jump up to 1000 and then dies all in one quick motion.
Old Feb 11, 2009 | 04:47 PM
Where's the Beef?
while i'm on the subject. My idle AFR is commanded around 14.8 and it starts off that way just great. but after a minute or 2 it richens up to abour 13-13.5 I can't seem to figure out why?
Maybe do some VE calibrating?
Old Feb 11, 2009 | 06:11 PM
Wheatley's Avatar
Truck Sponsor
Throttle cracker and also look into your throttle follower decay tables in gear
If you want,you can email me your file an I will take a look at it for you
charlie@gowheatley.com
Old Feb 11, 2009 | 07:47 PM
Where's the Beef?
sent.
Old Feb 11, 2009 | 08:49 PM
dc_justin's Avatar
Hello Dave
At low speed like you're desribing, throttle follower decay (increase slightly) and decay delay (increase at low rpm) will do wonders.
Old Feb 11, 2009 | 09:16 PM
2005 Silverado's Avatar
SPAM HUNTER
Not to thread steal, but why some tuners are near, At all and any first startups by truck idles up normal but then will drop like 300 rpm then just idle back up. Any advice on this? Also if i rev the truck up the rpm drops slowly, would playing with the throttle cracker alow the rpms to drop quicker.
Dustin
Old Feb 11, 2009 | 09:22 PM
dc_justin's Avatar
Hello Dave
Dustin
Check your various startup decay and delay tables. It sounds like it's decaying out a bit too quickly. Is your desired airflow table accurate?
Old Feb 12, 2009 | 12:34 PM
KLUG'S SS's Avatar
FormerVendor
That's what I was just getting ready to ask. Getting your desired idle airflow numbers in line is fairly important for a good idle.
Old Feb 13, 2009 | 04:18 AM
Where's the Beef?
Dustin
Mine idles fine at startup, but will go real lean 17-18 for a bit and then go where I want it.
I noticed an Engine enrichment Decay rate that leans out the mixture at start up after so many revolutions, but not sure what adjustments to make. I also noticed that the problem I'm having with it wanting to die is only when below operating temps, so I know something needs to be adjusted based on that. Just don't know what. Any ideas on these?
01silvy
Sep 26, 2015 10:20 PM
supershift67
Sep 18, 2015 08:21 PM
99bluefirebird
Sep 17, 2015 08:05 PM
Rockrz
Sep 13, 2015 12:22 AM
2500ZL1
Sep 12, 2015 03:50 PM
