For those of you that do your own tuning...
Old May 4, 2011 | 05:27 PM
Gadgetized's Avatar
Default For those of you that do your own tuning...
I have been using a friends EFI Live to tune my truck. I am running SD with a 2 bar map. How accurate are you able to get the AFR? I have always been a carb guy, and have logged my AFR with a carb, and it was always very close. The closest I can get my fuel injected engine is anywhere between high 13's, and mid 15's. Am I asking for too much, or should the AFR be closer to 14.7?
Old May 4, 2011 | 06:07 PM
tarinitup's Avatar
9 Second Truck Club
Is that at wot? If so you are pretty lean with forced induction.
Old May 4, 2011 | 06:15 PM
Gadgetized's Avatar
No, those are my cruising AFR's. I got my WOT anywhere between high 12's, and high 10's. I haven't messed with the WOT much yet.
Old May 4, 2011 | 07:50 PM
2007chevy5.3l's Avatar
My A/F bounces around from 12s to 15s just cruising. Never had any issues but im on motor so idk about FI
Old May 4, 2011 | 07:57 PM
blackcash's Avatar
Mine bounces from 14-15 at cruise, no changes other than zeroing out the fuel trims.
Old May 4, 2011 | 08:13 PM
Rhino79's Avatar
9 Second Club
I have bouncing afrs too, its similar to the o2's switching. 14-16
Old May 4, 2011 | 09:13 PM
tarinitup's Avatar
9 Second Truck Club
same here 15-16 aft at cruise
Old May 4, 2011 | 11:04 PM
jakebro's Avatar
When your crusing your afr is supposed to switch between slightly rich to slightly lean, that's also why your 02S's are constantly switching voltages..
Old May 5, 2011 | 01:25 AM
02'Z71ONDUBZ''s Avatar
Why dont you just run in closed loop?
Old May 5, 2011 | 08:12 AM
Country Boy's Avatar
Senior Member
I have never heard of bouncing AFR..
When I tuned my turbo Camaro, I ran 2 bar CLSD. I tuned it all in OL and it would be dead nuts 14.6-14.7 all day and exactly what I commanded in PE. My VE was dead accurate, but it took me 2 weeks straight of logging and changing to make it that way. I could pop it to OL and never even worry about it.
