For those of you that do your own tuning...
Old May 5, 2011 | 09:00 AM
dirt track racer 81's Avatar
Mine is dead on 15.8 no o2's.
Old May 5, 2011 | 10:10 AM
Gadgetized's Avatar
I am still in the tuning stage of this(after several months). I will be running a semi OLSD when and if it is ever done. I have ran countless miles, and logged numerous logs to try and nail down the tune. It actually runs pretty decent when cruising, but the AFR's are all over the place. It still revs to 3k when I start it, but it only stalls when a let off the gas once in a while. My tuner is confused, and says that my VE numbers are low, and that is causing my ignition to be quite a bit high. I have no idea why this is happening, and apparently he doesn't either. I want to get this running soon and drive it. I spent most of last year driving around burning up gas so I could send a tune log to my tuner so he could say hmmm.
Old May 5, 2011 | 11:10 AM
Country Boy's Avatar
Senior Member
SD is something that should not be mail ordered and it cant be done in a 1 hour "dyno tune".
Old May 5, 2011 | 11:23 AM
BlackGMC's Avatar
Resident Retard
Just takes experience. I can tune a ve table in 3 short logs, then 3 short logs for MAF, then 3 logs for WOT spark, then 2-3 logs for switchpoint adjustments. All together about 3-4 hours and i am done starting from stock maf, ve, spark tables
Old May 5, 2011 | 11:25 AM
BlackGMC's Avatar
Resident Retard
That is only true if it is a load bearing dyno which those are hard to come by
Old May 5, 2011 | 12:39 PM
Gadgetized's Avatar
I am logging data and emailing the tuner the logged data. He is then changing my tune, and emailing me back the tune to load. I have actually been getting it most of the way there before I send him logged data. He has been at it for months now, and I have been through numerous tanks of gas just to get it where it is.
Old May 5, 2011 | 01:00 PM
bigboy576103's Avatar
I have gotten our ve to be around 14.5 to 15. Open loop no problem like stated above jus takes time and patience.
Its importand to have ur scanner setup right as well other wise things will read diff that acually is. Such as ground offset on ur wideband!!! You could be runnin 14.5 but reading 15.8. !
Old May 5, 2011 | 02:15 PM
BlackGMC's Avatar
Resident Retard
That is why EFI Live V2 is awesome, no more analog logging, I use serial logging which is more accurate and does not suffer from the ground offsets like analog...
Old May 5, 2011 | 02:22 PM
Senior Member
The ground offsets are a major PITA. I have to redo it everytime I hook up the wideband.
Old May 5, 2011 | 02:58 PM
Gadgetized's Avatar
I am using the serial port too.
