<TECH ONLY>TQ Mgmt removal revisited & other tranny performance tables
Old Jul 17, 2006 | 08:00 AM
Wilde Racing's Avatar
How do I change this text
This is my forcing table, It was alot lowwer but with the 2.1.12 update and the Pressure Control offset (tcc) I was able to add line pressure for the convertor only during lock-up.
Old Jul 17, 2006 | 08:14 AM
A better screen shot.
Old Jul 17, 2006 | 09:50 AM
moregrip's Avatar
what a rush!
Here's my current table for comparison
Old Jul 17, 2006 | 10:32 AM
moregrip's Avatar
what a rush!
Originally Posted by Eye-P
I would leave the FMC table alone with a transgo. You are mechanically raising pressures already.
Not sure about the TCC duty cycle.
Here's what I have read on the matter:
"For the TCC, set the max table to 100 & the min table to 90. This gets rid of the TCC slip."
Old Jul 17, 2006 | 10:48 AM
Unless you have a 01-02 ECM, then the "Pressure Control" > "Offset (tcc) tabble works very well at adding line pressure for the tcc. Although I still bump up line pressure with the forcing motor table.
Old Jul 24, 2006 | 09:39 PM
moregrip's Avatar
what a rush!
I zero'd out all my Shift Properties|Desired Shift Time table a few days ago and the tranny is shifting more like it used to WOT now, next I'll add this to the mix:
and see what that changes, while doing some logging and report back
Old Jul 24, 2006 | 10:02 PM
So...you're not bumping line pressures on the upshift? How high do you plan to spin?
Old Jul 25, 2006 | 04:37 PM
moregrip's Avatar
what a rush!
been tuning and test driving all morning......
the truck is more responsive than ever with my current changes, 1-2 shift 3/4 throttle is awesome! the front end of the truck lifts........however my WOT 1-2 shift is still what I would consider "not right". for comparison for those that have done a transgo shiftkit the WOT 1-2 shift feels alot like a WOT 3-4 shift would. In every other instance it is spot on perfect.........anymore ideas?
the only table I have not modified is the Force Motor Current
Is there a chance something is wrong with the shift kit, any known problems?
Old Jul 25, 2006 | 06:07 PM
More than likely your settings.
kr1s
Aug 24, 2015 05:34 PM
Boombastic
Aug 5, 2015 11:38 AM
cbhedrick
Jul 20, 2015 10:12 PM
Chiphead
Jul 13, 2015 10:16 PM
jrplz
Jul 9, 2015 12:07 AM
