STS Basic Tune
Old Nov 7, 2008 | 04:24 PM
Mort's Avatar
Originally Posted by Coban
You think Id be able to drive it around if I just:
scale injectors (42lb'ers)
reduce timing
run 93
keep light throttle
monitor the wideband
What table do you actually edit in hptuners to increase the fuel? The LT and ST fuel trims? or is there a "master" table?
For daily driving you tune the Main VE table and then the MAF table for fuel unless you go 2 bar. For WOT you tune the PE Modifier Based on RPM. Then you scan the LTFT and STFT to see how you are doing. It may be tough to tune the VE table without going lean in boost so you may only be able to tune the MAF table. It may be a little hard to do with the fuel trims changing the fuel all the time so the PE table will be where most of the work is done for WOT only and hope the MAF keeps the rest in line. It should work fine until you change the cam and /or heads.
Oobray
Jun 13, 2022 03:38 AM
shawn96gmc
May 17, 2016 04:15 PM
jeff.ellis
Aug 18, 2015 10:34 PM
ZO6Ted
Aug 12, 2015 07:50 PM
4B11T
Jul 13, 2015 03:48 PM
