Strip preparation tuning
Old Oct 30, 2012 | 02:23 PM
chevyridinhigh22's Avatar
Default Strip preparation tuning
Hey guys, I'm about to hit the track with actual slicks FINALLY, lol. As I understand it I'm going from a 275/45/20 which is 29.7ish tall. I got some 28" Hoosiers for it. When I change the diameter in HPTuners will it bounce off the rev limiter before shifting or even shift at all? What do you do to prevent that? I'm pretty f n lost when it comes to hp! I'm running a 215/75-16 up front also.
Old Oct 30, 2012 | 03:46 PM
oakley6575's Avatar
You can change it in HPT and it will automatically change the shift points. But you really don't know if it will be perfect or not. You will have to fine tune the shift mph when you get to the track. I always make the shift mph four or five mph less than where it should shift. That way it will shift right at the WOT rpm you set. Hope that helps
Old Oct 30, 2012 | 03:57 PM
nonnieselman's Avatar
just subtract about 5 mph from your 1-2 and 2-3 WOT upshift. if that dont work,, subtracto another 5mph..
Old Oct 31, 2012 | 01:30 PM
BigKID's Avatar
The trans is going to shift based on wot rpm as long as the wot shift mph is met (or vice-versa in your case). Set the wot mph shift point according to a 28" tire and leave the tire size as your street tire. Mine is set up this way and I don't change the tune when I go to the track swapping out my 29" street tires with a 28" slick and it shifts at set rpm both on the street and track.
Old Oct 31, 2012 | 01:40 PM
Okay thanks fellas... The 27" front won't affect anything correct? Mph is based off of the rear wheels right?
Old Oct 31, 2012 | 03:19 PM
oakley6575's Avatar
Yes, front tires don't matter
Sierra1320
Aug 15, 2015 08:04 PM
vipergtrdj
Aug 6, 2015 10:19 PM
Cm_gmt800
Aug 3, 2015 09:13 PM
carid
Jul 24, 2015 05:00 AM
dantheman1540
Jul 11, 2015 04:07 PM
