Startup Tune for the Project Truck
Old Nov 11, 2007 | 10:31 PM
  #51
dc_justin's Avatar
Hello Dave
Yeah, it's close, just not quite.
At 0 manvac, you've got 58psi of differential pressure... those injectors flow 72.3# at that point and slope up.
At 80 manvac, you've got around 69.5psi of differential pressure... The injectors should flow 79.1# at that point. Slope it evenly between those points.
Old Nov 11, 2007 | 10:36 PM
  #52
Stoichiometric's Avatar
So the only thing we are concerned about to determine the flow rate is differential pressure? Just need to convert kPa to psi or visa versa. Thanks Justin!
Old Nov 11, 2007 | 10:39 PM
  #53
dc_justin's Avatar
Hello Dave
Yes. You multiply the known flow rate by the square root of the change in differential...
Example.
Injectors flow 63.2# at 43.5psi. GM operates at 58psi. Take 63.2 x sqrt(58/43.5)
Apply that formula to the IFR table.
Old Nov 11, 2007 | 10:40 PM
  #54
moregrip's Avatar
what a rush!
how does this look?
Old Nov 11, 2007 | 10:44 PM
  #55
That was the formula I was searching for, I remember you helping me with my injectors not too long ago. I still owe you lunch
Old Nov 11, 2007 | 10:46 PM
  #56
Looks good now Grippy, just need to make sure the fuel pressure stays at 58 psi and you're in business.
Old Nov 11, 2007 | 10:47 PM
  #57
dc_justin's Avatar
Hello Dave
IFR looks good... have the injector x volts table about 50% higher than the one you posted up and you should be good.
  #58
moregrip's Avatar
what a rush!
Example.
where does the 63.2 @ 43.5 psi rating come from? I ask because that value is greater than the manufacturer spec is I've seen for them.
Old Nov 11, 2007 | 10:51 PM
  #59
moregrip's Avatar
what a rush!
this table needs to be 50% higher?
Old Nov 11, 2007 | 10:55 PM
  #60
dc_justin's Avatar
Hello Dave
From racetronix:
Static Flow Rate @ 43.5PSI (300kPa) w/Gas: 63.20 lb/hr = 668 cc/min = 475 g/min *
The shorties are listed at 60#/hr...
