Startup Tune for the Project Truck
Old Nov 11, 2007 | 04:50 PM
  #41
moregrip's Avatar
what a rush!
Ya I found the thread, the problem is I have found numerous statements of different values that work... There seems to be allot of varience. It would be nice if we could get them flow tested at all the key settings.
I thought Siemens was forthright with that data
Old Nov 11, 2007 | 05:21 PM
  #42
moregrip's Avatar
what a rush!
got these specs from a search, are these the standard #'s everyone is using?
Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min
Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min
Gain: 0.11ms/mg
Offset: 0.055ms
Turn on time @ 14VDC: 1.14ms
Turn off time: 0.85ms @ 600KPa
Connector: Bosch EV1
Orifice Type: Multi-orifice
Spray Pattern: 30 Degree Spray Cone
Factory fitted with Viton upper and lower o-rings
Old Nov 11, 2007 | 05:42 PM
  #43
03sierraslt's Avatar
Ya but that doesnt really help in determining the Offset values as well as the min pulse values. It gives you the IFR but as for the offset vs. Inj. volts???????
Old Nov 11, 2007 | 06:21 PM
  #44
moregrip's Avatar
what a rush!
I was looking at someones tune and it looks like Default Injector Pulse was modified as well
Old Nov 11, 2007 | 07:32 PM
  #45
I set mine to the same as what my Min pulse is.
Old Nov 11, 2007 | 10:06 PM
  #46
Stoichiometric's Avatar
Grippy, I did some searching for the formula to figure out your injector flow rate based on manifold pressure, didn't find it yet. dcjustin or KB might know it. You will want you IFR table to look similar to this one.
Old Nov 11, 2007 | 10:09 PM
  #47
The correct IFR is the main thing to get you going, other parts of the tune will use these numbers to calculate airflow which will also effect your timing. The pulsewidth adjust may need some tweaking as you refine the tune, it might not be spot on the first time.
Old Nov 11, 2007 | 10:24 PM
  #48
moregrip's Avatar
what a rush!
IFR is the most important thing to get me going, roger.....how does this look for the 60lb injectors?
Old Nov 11, 2007 | 10:27 PM
  #49
It looks close. Did you use a formula to calculate each kPa cell?
Old Nov 11, 2007 | 10:28 PM
  #50
moregrip's Avatar
what a rush!
negative, looking at someone elses tune
